Just wondering if it would be safe to use hard water spot remover from the marine line,I have a suv to do that has bad water spots from my customer using well water.Water spots everywhere,wouldn't this be faster than claying the whole vehicle. barry
Hard water spot remover from Marine line
Re: Hard water spot remover from Marine line
Originally posted by barry View PostJust wondering if it would be safe to use hard water spot remover from the marine line,I have a suv to do that has bad water spots from my customer using well water.Water spots everywhere,wouldn't this be faster than claying the whole vehicle. barry
This questions comes up once in a while and the answer is that the M47 Hard Water Spot Remover was formulated for and intended for the type of water spotting common to marine surfaces and for these problems it works pretty well.
When you jump over the automotive world the biggest problem people have with water spots is the etching the water leaves in the paint, we're taking about a crater in the actual pant and wiping on M47 Hard Water Spot Remover to paint like this isn't going to fix the problem because M47 isn't abrasive and isn't going to remove any paint.
The way you remove a Type II water spot or etching in the paint is to remove enough paint surrounding the etching to level out the surface. This means using a compound, not a wipe-on, wipe-off liquid.
Now if the spots you're trying to remove are a mineral deposit, sitting on top of the paint, the it might work and you can certainly test it but again, it was formulated for and intended to be used in Marine applications, not automotive.
Originally posted by barry View PostThanks Mike,I think I'm going to give this a try,because I think its only on the surface and not in the paint.I'm going to get some M47 and try a spot.
For everyone that reads this into the future, the front label does state it's for deposits, those are usually minerals sitting on the surface, not etchings, which are defects in the surface.
And the back label does address the etching problem with more information as it relates to working on marine surfaces.
