Hard water spot remover from Marine line
Results 1 to 7 of 7
Thread: Hard water spot remover from Marine line
    Registered Member barry's Avatar
    Feb 2004
    Jackson,Tennessee
    57
    79
    16
    Just wondering if it would be safe to use hard water spot remover from the marine line,I have a suv to do that has bad water spots from my customer using well water.Water spots everywhere,wouldn't this be faster than claying the whole vehicle. barry
    barry
    Recovering PC Addict Bounty's Avatar
    Apr 2009
    Jacksonville, Fl
    541
    28
    Re: Hard water spot remover from Marine line
    Quote Originally Posted by barry View Post
    I have used the Marine Line Hard Water Spot Remover in a pinch on trim/glass/plastics but for paint I'd run down to the local Wal-Mart, Autozone, etc and grab either SwirlX or Ultimate Compound after washing and claying the vehicle.
    Jan 2009
    New Lenox, Illinois
    10,362
    300
    ScratchX 2.0 would work well too.
    38
    19,070
    235
    Are the hard water spots on paint?
    If so, you are safer with the proper paint care products.
    58
    24,767
    518
    This questions comes up once in a while and the answer is that the M47 Hard Water Spot Remover was formulated for and intended for the type of water spotting common to marine surfaces and for these problems it works pretty well.
    When you jump over the automotive world the biggest problem people have with water spots is the etching the water leaves in the paint, we're taking about a crater in the actual pant and wiping on M47 Hard Water Spot Remover to paint like this isn't going to fix the problem because M47 isn't abrasive and isn't going to remove any paint.
    The way you remove a Type II water spot or etching in the paint is to remove enough paint surrounding the etching to level out the surface. This means using a compound, not a wipe-on, wipe-off liquid.
    Now if the spots you're trying to remove are a mineral deposit, sitting on top of the paint, the it might work and you can certainly test it but again, it was formulated for and intended to be used in Marine applications, not automotive.
    Feb 2004
    Jackson,Tennessee
    57
    79
    16
    Thanks Mike,I think I'm going to give this a try,because I think its only on the surface and not in the paint.I'm going to get some M47 and try a spot.
    barry
    58
    24,767
    518
    Let us know if it works for you or not.
    For everyone that reads this into the future, the front label does state it's for deposits, those are usually minerals sitting on the surface, not etchings, which are defects in the surface.
    And the back label does address the etching problem with more information as it relates to working on marine surfaces.
  1. Meguiars Online Acronyms - Product Links
    By gb387 in forum Discussion Forum Related Basics & How To Articles
    Last Post: Mar 23rd, 2016, 09:12 AM
  2. If it wasn't for bad luck I wouldn't have any Luck
    By Graeme in forum Detailing 101
    Last Post: Dec 27th, 2006, 02:25 AM
  3. little problem here, lots of water spots
    By maxima2k2 in forum Detailing 101
    Last Post: Mar 10th, 2006, 07:11 AM
  4. Gold Glass residue
    By KLnyc in forum Detailing 101
    Last Post: Jul 12th, 2005, 04:38 AM
  5. water spot remover
    By DSG Man in forum Detailing 101
    Last Post: Oct 3rd, 2004, 04:40 PM
