Here is my little experience with the G220. I bought one summer 2008. And polished 4 cars before I found the machine behaved strange. It would almost not rotate anyfurther, anyhow. (And yes, easy use, almost no pressure). I took the backplate off and tested the machine just in the air. And it rotated only occasionally. And well, something was seriously wrong.. I went to the dealer and explained and showed up the machine. They had been notified that this was a problem on the first models they received. And I got a new one without any problems. I have polished one car last year with the new machine, and was a bit in doubt if it was fine. Now its spring, and I was about starting with my car. And, I'm sorry to say, but I think I see the same problem again. Machine is working "fine", but I think its getting weaker and weaker to rotate. But now I thought that I must research this. I unscrewed the backing disk and "clutch", where I find two roller bearings mounted in the eccentric house, and a shaft goes right through these two bearings. And here I see the problem. Shaft is not tight to the bearings. Instead the shaft is slipping on the inner ring of the bearing. And has worn itself thin and there is sign of it has gone warm. The effect of the bearings are then lost, and therefore this of course will make the "clutch" to malfunction. I think this looks disappointing. Very very poor technically build. So the questions is, may I got a machine that has the same factory failure as the first one? Has this problem been improved? It should be grooved pattern in the innerring and on the shaft. Then this problem should have been solved 100%.
And do not mention that I have used the machine faulty. Because I use the machine gently and soft, and almost its own weight as pressure.I do really know about this use. Corners, curves and so its hopeless with G220, so I fix them by hand. Its not that either. And whatever how you use it,the problem will still be there. This weakness is not going away whatsoever. So, if I can replace anything yet again, is this problem fixed/improved?Or are G220 still build like this? If so, this machine ends up in the trash and I go to the purchase of a Flex. This just does not hold. At the first place, this is very disappointing product from Meguiar's! At least from my point of view.
