Just bought a RO polisher/waxer and the 3step cleaning kit how do i use it?
Results 1 to 10 of 12
Thread: Just bought a RO polisher/waxer and the 3step cleaning kit how do i use it?
    Jun 2009
    PEI, Canada
    14
    This is my first time detailing a car so i need some guadiance, thanks in advance, Ok i just purchased http://www.canadiantire.ca/AST/brows...2BPolisher.jsp it comes with 2 cotton polishing bonnets, 1 cloth wax applicator and 1 foam wax remover, i also picked up http://www.canadiantire.ca/AST/brows...r%2BSystem.jsp but mine has a micro fiber cloth instead of the cleaner, I also picked up the maguiares 3 step cleaning kit, so i'm basically wondering what do i apply with the buffer, and with what pads and when? Like if someone could explain it too me as if i was a cave man. Like i have read some stuff ppl saying apply this then remove access with a cloth but do you do that with a buffer?
    ps sorry for the wall of text just allot going through my head.
    Jun 2009
    PEI, Canada
    14
    Re: Just bought a RO polisher/waxer and the 3step cleaning kit how do i use it?
    anyone1?
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    60
    You can apply and remove wax with the Simoniz buffer. It's an orbital buffer, or what is commonly referred to as a wax-spreader on this forum. It really has no correction ability, which is why it sells for as low as it does. If you are looking for a machine to remove scratches, swirls, and other paint defects you would need to step up to a Dual Action Polisher.
    See this link:
    Machine Photos - DA Polishers - Rotary Buffers - Traditional Orbital Buffers
    Jun 2009
    PEI, Canada
    14
    i understand that, i don't want too get one of the more powerful ones cause i could ruin my paint, i don't know what i would be doing. So do i use the buffer i have to apply scratch x 2.0 and my polish and my wax? and also use it too remove it? And what is the "foam wax remover" thing for that came with it?
    'Pearly Gates' Eddie6th's Avatar
    May 2009
    Italy
    3,169
    89
    Hi stoop,I've noticed you've opened another thread here.I think you're putting to much on your plate in one go.Stick with the advice already given to you by the users and take it one step at a time.I can understand your concern,but your car will still be there tomorrow,and the day after etc.,so don't get yourself in a muddle,trying to deal with too many questions in one go.
    Feb 2009
    Powell, Tennessee
    30
    3,543
    130
    OK, let's try to get some of your questions answered. You have:
    an orbital buffer
    2 bonnets
    1 foam wax remover (not sure what that is, can you post a pic?)
    Mother's clay bar system
    DC1 Paint Cleaner
    DC2 Polish
    DC3 Carnauba Wax
    Scratch X 2.0 (correct?)
    OK, let's start with the basics. First you will want to wash your car, using a good quality car wash. Meguiar's makes several, and you can usually find at least one of them wherever car cleaning products are sold. After you do that, you have one of two options. You can either dry off the whole car, and clay the car, wiping off the residue from the clay bar and your lube as you go, or you can just get most of the water off, clay the whole car, and then go back and re-wash to remove the residue. Personally, I like to do a re-wash after claying. Make sense?
    At this point you're ready for your paint cleaner, which for you would be either DC1 or Scratch X 2.0. Both of these are fairly mild, so if your paint is not in too bad of shape (meaning few or no swirl marks) you can use one or the other. You don't need to use both. DC1 is milder than Scratch X 2.0. If you have swirls and whatnot in your paint, you will need to step up to Swirl X or Ultimate Compound. The orbital polisher is worthless as far as paint correction goes. This will need to be done by hand. Read this thread: How to remove a defect by hand with Scratch X.
    After that you can move on to DC2. With DC2, work small sections (for example, a door would need to be split up into 3 - 4 sections), work the product in for a few seconds, then immediately wipe off. DO NOT LET THE POLISH DRY. Note that this step is completely optional. You can do it or you can skip it - it's completely up to you.
    After that, you can wax. Here's where you can use the orbital if you'd like. On the up side, an orbital will help you wax much faster. On the down side, it's much harder to get in little places like under the door handles and places like that. Those areas you will have to do by hand. When using the orbital, put 2 rings of product on the pad: one on the outer edge, and one about halfway in. This should be enough product for 1-2 normal sized panels (such as the driver door and the rear door). ALWAYS THINK THIN. Applying the product thick will not gain anything. By applying the product paper thin, it will dry faster and be easier to take off. You don't want to wind up with your panels looking like this:
    It should look more like this:
    To remove, do the Swipe Test, and when the wax passes the test, remove with a microfiber towel (make sure you have 2 microfibers handy). After you have removed all the wax, you can go back over and wipe the car down with Quik Detailer or Ultimate Quik Detailer if you'd like. Use a clean microfiber for your wipedown. Well, I think I've answered all your questions. Hope this helps!
    Jan 2009
    New Lenox, Illinois
    10,362
    300
    Just to add to what Ciera said, This is the order of aggressiveness for the products your interested in:
    DC1
    SwirlX
    ScratchX 2.0
    Ultimate Compound
    May 2009
    Italy
    3,169
    89
    Thankyou Ciera for intervening to help this chap out.I have to go offline for now!
    Feb 2009
    Powell, Tennessee
    30
    3,543
    130
    Oh, I guess I should add these videos for you to watch:
    How to Wash Your Car (ShowCar style)
    How to clay bar
    Jun 2009
    PEI, Canada
    14
    I posted a few pics of the scratched on my car and eddie says i'll need a touch up pen to fix them, Should i wait to clay,polish, wax till i get my touch up paint? Or should i clay today touch up tomorrow and finsiht he polish wax tomorrow too?
