Spots white
  • Spots white
    Hi, why do I get tiny white spots in my dark finish ,looks like salt has been sprinkled on the surface in different areas? I am using Meg. Cleaner/Wax.
    Thanks
    Re: Spots white
    It could be rock chips in the paint. After you waxed the vehicle the wax is in the chips and made them more noticeable.
      Re: Spots white
      Where are the spots at? Are they centered in one area of the car or are they scattered all over?
      By the way, seeing this is your first post, to MOL!
        Re: Spots white
        They are scattered all over it almost seems like tiny improfections in the finish.
          Re: Spots white
          You might want to try claying next...
          Use the Smooth Surface Clay kit.
            Re: Spots white
            Water spots? Acid rain?
              Re: Spots white
              Please post some photos for us.
              --Al Kimel
                Re: Spots white
                Moved to Detailing 101 as this is a detailing related question, "New to the forum" is for technical forum use questions.
                When in doubt, if you have a detailing related question, use Detailing 101
                  Re: Spots white
                  Maybe hard water spots...
                  Clay bar first
                  Skoda Roomster
                    Re: Spots white
                    sounds like chips filled with wax.
                    Any pics?
                      Re: Spots white
                      Any pics?
                      Me think so too.
                        Re: Spots white
                        If that's the case, then a 50/50 water/alcohol solution should be able to remove the wax residue in the chips. Of course, you'll then need to re-wax the surface.
                        --Al Kimel
                          Re: Spots white
                          Really?
                          I would never use this combo.
                          I would be afraid of all the run off drying out any plastic or what ever it comes in contact with.
                          What has been your experiance with this combo?
                            Re: Spots white
                            Really?
                            Yes, really, Mario. A 50/50 alcohol/water solution is commonly used in detailing circles to remove waxes and polishing oils.
                            --Al Kimel
                              Re: Spots white
                              I must be heck of a lucky!
                              On the forum,I've heard of plastic trim detailers running when it rains..I've never had that problem.
                              This problem of wax in stone chips,turning white....Again,I've never had that problem either.(Although I have seen this before on other cars).
                              Are some people putting too much product on and not wiping off properly?
