fiberglass RV
Results 1 to 4 of 4
Thread: fiberglass RV
    Jun 2009
    Green Cove Springs, florida
    fiberglass RV
    I have a 2001 Thor Citation, a fiberglass travel trailer. I have noticed a bubble in the front of the camper and upon inspection, it appears to be liquid-filled. If it is, I guess I have a leak in the roof, but there are no tell-tell signs on the inside, just the bubble on the outside, which appears to be between the fiberglass and whatever the fiberglass was applied to. What could this be? Also, how is this shell of the camper constructed....is it fiberglass applied to wood, such as plywood?
    I appreciate any help I can get.
    59
    24,767
    519
    Re: fiberglass RV
    IF you haven't already, you might check with the manufacture about both the bubble issue and the method of construction.
    Here's there website,
    Thor Industries
    Most of the Fiberglas exterior campers/trailers I've been around have been Fiberglas over wood construction.
    Registered Member Poki's Avatar
    Jul 2008
    U.S.A.
    547
    21
    Re: fiberglass RV
    Sounds like what you are describing is "delamination". Not sure about the liquid. Delamination occurs when the gelcoat or fiberglass or? start to separate. If this is what you have....I know of no fix other than replacing the wall section. In the case of a 40 ft RV with sidewall delamination, the fix is to remove the entire wall and replace it. A VERY expensive fix. Maybe there has been a newer fix that has come down the live that I am not aware of....sure hope so!
    Barry
    59
    24,767
    519
    Re: fiberglass RV
    Quote Originally Posted by Poki View Post
    That's what I thought as he described the bubble. If it is delamination no amount of polishing is going to fix it. Time to have it inspected by someone knowledgeable in the construction of RV's.
  1. Fiberglass Corvette
    By Carfire in forum Detailing 101
    Last Post: Nov 5th, 2008, 02:59 PM
  2. Replies: 13
    Last Post: Jun 12th, 2008, 02:42 PM
  3. Cleaning up fiberglass???
    By vettemaniac in forum Detailing 101
    Last Post: Feb 14th, 2007, 04:13 PM
  4. corvette fiberglass...
    By Ace22 in forum Machines - The Dual Action Polisher
    Last Post: Sep 28th, 2005, 06:44 AM
  5. Meguiar's on Fiberglass?
    By chroma in forum Detailing 101
    Last Post: Aug 30th, 2004, 03:39 AM
