I once put swirls in my paint just to see what it looked like. I don't always detail cars, but when I do, I prefer Meguiar's.
Remove swirls my friends.
Just bought my makita 3 days ago. Love it. Never tried flex RB before. so can't say much. For makita i love.
1. Soft start
2. 'Clicking' speed dial
3. The trigger lock
4. The head can be hold not as hot like hitachi.
But then because i never tried flex before. So cant help much here. sorry
Detailers clean places nobody see. Detailer see's things nobody else see. But if you ask a Detailer to see how a dress looks on a woman, they are blind.
Tough call Andrew. I have the luxury of the G110, FLEX 3401, and the Makita... but I would say I reach for my Makita the most, and the G110 after that. The only time I reach for the FLEX anymore is when something just won't finish out right with the Makita and I am in a hurry.
I just love how effortless it is to use the Makita, where as the FLEX wants to fight you and grab the surface more (most of the time). When I am detailing for 10+ hours the reduced work comes into play.
It might just be a wacky personal preference, though.
On this one I think he's referring to whether to get a Makita rotary or the Flex rotary (3403) as referenced in his links. If that's the case you really cannot go wrong with either one.
I have used three rotaries in my life...the Porter Cable, the Makita, and the Flex. The weight of the Flex is obviously an advantage as is the ability to wield it longer with less fatigue. Ergonomics are nice as are quality and fit-and-finish. Using the Flex rotary is really what sealed the deal for me and made me purchase the Flex dual-action polisher. It's got all the features such as variable speed from 1.1k to 3.7k rpm's and onboard electronics for speed control, start-up protection, overload protection, and temperature monitoring. Also has the same soft-start/variable speed trigger and speed switch design as the Flex DA. Automatic shut-off if the carbon brushes wear down to save the unit. Oh and did I mention it weighs only 4.75 pounds...versus 6.6 pounds for the Makita? The other thing that turned me off to the Makita was the looped handle design versus the Soft-Vib handle of the Flex 3403. The Makita's low speed setting of 600 rpm's is indeed the lowest of any rotary I've seen but I've never applied an LSP by rotary so not an issue for me.
Best bet would be to see if you can test run some rotaries before committing but either of your choices are good ones...
I agree. you should test this two Rotaries first before purchasing. Different people have different taste. It the best way to know which one you prefer.
This may sound dumb, but how would I be able to test out the two rotaries?
I have not used the Makita rotary, but I have the Flex 3403 rotary along with a Porter cable 7428 and some other 50 dollar rotary I got off of ebay. The Flex is the only one I use due to it's weight, it's very light and easy to control. It has a 10 Amp motor, so the power is not an issue with it, but I would say the 1100 RPM's (lowest setting) could be an issue for someone and the stock handle, I removed mine and used a side handle.
Borrow from someone if you want to run them on a paint surface or go to a local distributor and ask if they have demo models to play around with a bit in the store. Being in California and provided all the members we have from there I'd venture someone would let you come over and experiment a bit...
Why exactly does 1100 RPM's (lowest ssetting) create an issue? Are you referencing for applying LSP's? I have a G110, so I would beusing that to apply LSP's anyways
I know Meguiar's has DeWalt and Makita rotaries. I could try out the Makita there, but I have never used a rotary before and would not want to test it on my truck, nor does my truck need the attention of a rotary.
I guess I could always go get a scrap panel (which I would do anyways to learn on) and bring it to meguiar's and try it out
I never said 1100 RPM's was a problem for me, but I've read where others like to finish down or "jewel" at 600-900 RPM's. I personally think 205 on a black finishing pad at 1100 RPM's looks marvelous!
It's a good machine, and I could say wtih confidence you would not be disappointed, but also you couldn't go wrong with Makita either. I guess it all depends if a rotary being lightweight is important to you.
Hah, that's what I get for not clicking the link.
I can't help you there Andrew as I have not used the FLEX rotary.
Bringing this thread up from the dead, I never did purchase a rotary, but I probably will this summer.
Just wondering if anyone else has any opinions on the flex rotary vs the makita rotary?
