Finally got a chance to try this product two days ago - on black paint nonetheless.
Ultimate Compound is like nothing I have tried before. I applied it with the G100, and the product had very good workability characteristics...much like the 80s series of products. Removal with a terry towel was a pill however. There were times when I thought I was trying to break up and remove #7 polish instead!
UC tended to smear with Meguiar's Super Plush terry towel...to the point that I had to resort to using a microfiber towel for the final wipe. The MF towel removed the residue nicely, but just when I thought I was ready to wax, the evening sun exposed some horrendous towel marks (from much terry towel wiping no doubt).
I then decided to hit these areas with D151 / W-8006 combo on the 5 setting, let it dry to a touch and remove the residue with a MF towel. Later, I came back with a coat of #21, and the finish really stood out.
Ultimate Compound truly does leave the finish ready to wax, but I would suggest removing the residue with a good quality microfiber towel - such as Meguiar's Supreme Shine MF, or you may run into what I did, and have to redo the panels.
As for UC's ability to remove paint defects, I was disappointed to say the least. It will remove oxidation with ease, but it wasn't too good at removing below surface etching. First, I started out with a W-8006 pad at the 5 setting on the G100. And after getting nowhere with this combo, I went against my better judgment and changed to a W-7006 pad at the same 5 setting. That combo worked the best of the two, but no better than #83 DACP.
Maybe I'm being a little too harsh on Ultimate Compound since it was my first time using it, but I just can't see where this product warrants such a high aggressiveness ranking. If I had to rank it, I would put equal to maybe, say, MPPC (Mediallion Premium Paint Cleaner), but less than DACP (Dual Action Cleaner Polish).
To UC’s credit however, it did leave an incredible gloss.
