Washing off old dirt and grime
  • Washing off old dirt and grime
    Hi All,
    I have a question about dealing with really old dirt and grime. My dad's 70 1/2 camaro has been sitting in the barn for too long. Not sure when it was last washed. I think it's been a sad thing for him to think about for many years so he's just avoided it. Anyway, I recently enrolled in ohio tech's classic car restoration program and will sooner or later be bringing the car back to life. For right now I just want to start by washing this stuff off. Any suggestions on a good product to soak with first to gently remove this stuff? here she sits.
    Re: Washing off old dirt and grime
    I would flood that car with water at least a couple of times, starting at the top and flushing the water downwards. After that, a gentle careful wash with Gold Class and definitely two buckets with grit guards. I think I'd be changing the rinse water frequently as well. Go slowly and wash it carefully. I bet it looks pretty good under all that dirt.
    Have fun!
    1968 Mustang Coupe Candy Apple Red
    1990 Limited Editon Mustang 5.0 Convertible (7UP Car)
      That's dirty!!!! I would def use a pressure washer and a foam gun before touching it with a mitt and 2BM with grit guards. If you don't have access to a pressure washer I would take a hose on high pressure and get as much off as possible and then use a gilmour foam gun ($35 on amazon) and let it soak for a bit.
        I do have access to a pressure washer. I thought that might be a little intense for a start however thats why I came here asking questions, I don't know where to start.
          I wouldnt worry about a pressure washer. A foam gun might be nice.
          Basically, just get it out in the open, and start hosing it off. Most of it is just dust, not like it is mud or grit.
          Hose it off good, then just wash it like usual, though you may need to change your rinse water bucket a few times. And a little extra soap in the wash bucket, might need refilled once or twice.
          How to Wash Your Car Show Car Style
          That will be fun to clay and clean, it will look night and day different even just doing basic steps by hand.
            Before you use a pressure washer, try spraying it with a regular garden spray gun first. The dirt may just slide off with a powerful garden spray gun. Pressure washer may chip and peel the dried, neglected paint that may be lying on top of a layer of rusted metal.
            With a car this dirty, I highly recommend you wash the car with something like APC+ or some sort of Gentle Dish Washer soap, like Palmolive or Dawn. Regular car wash soap is not powerful enough to cut through the dirt. The Mirror Glaze Hi-Tech Wash may be powerful enough, but it is relatively expensive and still not be powerful enough compared to APC+ or Dawn/Palmolive. Change your bucket of soap water frequently to prevent scratching the paint (detergent is cheap anyway). Hose off your wash mitt or sponge after cleaning each panel.
              There is no need to use strong products to get some dirt and dust off of a car.
              A mild soap, a mild claying, and detailing with mild products will have it looking brand new, with no need to strip more oils from the paint.
              Blast from the Past! - Bringing the Dead Back to Life
                Hello,
                Unless I am reading this thread incorrectly, which I am not, the car has been sitting for a long time. From what I could gather from the picture, the stuff on the car isn't just "some dirt and dust". It's a layer of really old dirt and grime compacted by moisture and the passage of time.
                The link you presented above demonstrates a relatively clean car with some heavy oxidation, not one that is anywhere as dirty as the one shown in this thread. Look at it! Can you even compare to two?
                Many users on detailing forums such as autopia, autogeek, or even on MOL, wash their cars with Dawn on the special ocassion to rid the car of heavy grime and dirt. It just seems this is the ocassion. Using a relatively more powerful detergent will make the cleaning process much easier, and makes claying much more pleasant. Whether Dawn strips oil or not, that is a long debated topic. Despite the cleansing ability of such soap, it hasn't stopped many people from using it.
                  Originally posted by matchstick View Post
                  Couple things I notice right off the bat. Firstly there is a lot of dust, dirt, and particulate settled on the car. If the car is washed fairly regularly this will come off with a basic pre-soak and rinse. Since the car has sat for quite some time, more than likely humidity and heat have cause some of this dust and dirt to begin to adhere to the paint surface...particularly if there was no wax or other protectant on the surface prior to storage.
                  In addition, there appears to be some fluid drippage along the rear glass and onto the trunk lid. Looks a lot like when a car is parked under another on a lift and tranny fluid, oils, etc drip down. This is more of an issue since those fluids tend not to rinse away with just water and standard car shampoo's...especially if allowed to dry. I'd pull/push it out of the barn and rinse it down first with your garden hose on a light rinse setting first then follow with the high pressure setting. Next up is a pre-soak with a citrus-based cleaner or Dawn dishsoap. The oil-cutting properties and harsher alkaline solvents will help to dissolve the oils and remove embedded grime. The main issue with not using these products on cars is that they tend to dry out exterior rubber, vinyl, and plastics when used repeatedly over time. As you can easily tell from the photo, these older cars have little to no exterior rubber, vinyl, or plastic to damage.
                  After your soak/rinse then mix up some heavy soap solution with Meg's NXT car shampoo (water softeners and particulate encapsulators) and wash thoroughly with a foam gun/1-bucket method or the standard 2-bucket method with grit guards. Be sure to dump out your buckets about halfway through or if heavily soiled and continue. Use APC+ on the wheels/tires/wheel wells. Dry properly and you should be good to go.
                  Remember afterwards to either use a car cover to protect it or wash weekly to maintain the paint condition in as best a shape as possible.
                  Hope this helps...
                    pretty much as above.If you foam it,you might want to let the soap sit for a bit first,but don't let it dry.Work in the shade or in the early morning when it's cool.If it was me,i'd just rinse off the first soap by hose.There is so much on there,you might create scratches while you're passing with mitt or sponge.After that,I'd soap it again and wash as normal.In this case,i'd definitely use the 2 bucket method and grit guards if you've got.
                    Once you're satisfied that the car is washed completely,you'll need to clay it.There will be a lot of contaminents stuck to the paint.
                    As mentioned earlier,it's not known what the fluid spills are on the back,so you'll need to see after the claying what is left to do.
                    It'll be great to see some after shots.
                      I realize the Mercedes is a bit cleaner... I was just trying to point out that working with a milder product can have great results.
                      I do not know if you will find stubborn things on the paint, maybe you will, maybe not. Often with old cars, you almost have to detail them once to find the problems, then detail again to fix them.
                      It is more a situation where you can wash the car mildly, and then use a stronger product only on the areas that need it.
                      Even if a few stubborn spots are there that can be mildly clayed, it is better for old paint than to use a strong chemical.
                      It is always possible that the whole car may need something strong, but it seems unnecessary to jump right to that.
                        Those aren't fluid spills on the back I'm pretty sure they're cat tracks. I'd have to go look again. Anyway thanks for all the great information guys! I think we're gonna roll it out today. I'll post pics if we do.
                          Sounds good, always helps to see more of what you are working on.
                            Ok So we rolled her out today, we live on a farm and I didn't feel like running into town to buy a bunch of stuff so we followed mike's thread on cleaning off that red mercedes as close as we could with what we had. We washed it off with water. Then, washed it with a turtle wax car wash. then she went back in and we followed up with a product called safe cut trying to get rid of oxidization, then we polished, then followed with two coats of wax and a car cover. This car has been sitting for about 10 years. It has surface rust in a lot of places but the main point of this was to get my dad in the mindset of bringing back the only car he ever bought brand new. It only has 40,000 miles on it. It's a crime it sat this long. He did cuss for a while through the beginning. thanks for all the info guys.
                            start
                            after we were done waxing.
                            the chrome shined up ok too
                            In this close up of the hood you can see the reflection of the roof of the barn so for original 40 year old paint it still shines.
                            covered up.
                              nice to see that lovely paint shine again!
                              I noticed the rust spots around the back.Is that the only place?
                              Keep on it,and get the rust fixed.it's a nice car.
