This is my first post in the forums.
So I was checking out my truck tonight because I had to check up on some stuff, and then I noticed that the the truck bed was keyed! Upon further inspection, the whole passenger side was keyed!!! (why?! )
Any suggestions to fix this? I know that I need to fix some parts asap because some of it goes to the metal (going to use touch up paint), but is there anyway to fix without having to go to the shop? Its a Tundra with Thunder Grey Metallic as the paint.
I'm going to follow Mike Phillips advice on touch up for rock chips:
but is there any other way to fix these scratches without wet sanding (have no experience but my friend does)
Pics will be posted tomorrow
Chip repair is never easy and unless you have some experience with this type of thing then it can be very challenging to make the repair actually look good. Paint chip repair consists of two things,
Applying touch-up paint
Making the repair look good
That's two things and the second one is the hard one, anyone can dab some paint to the surface.
Meguiar's doesn't have an official "how-to" on chip repair, the best thing you can do is NOT use the brush built into the cap, instead use a toothpick or do like I do and go to an artist supply store or a craft supply store and purchase a couple of very fine tipped artists paint brushes and a little bottle of paint thinner to clean the tips and the brushes are not cheap. Clean the chipped area as best as you can with whatever tool/brush/pick etc. you can find and then apply just a little touch-up paint into the chipped area and then stop and walk away from the car. Allow the paint to dry for a couple days and then inspect, if you see that you have room to apply more touch-up paint then apply a little more and again, stop messing with it and let it dry.
Most people use the brush that comes built into the lid and go from a divot, (a low spot in the paint), to a blob, (a high spot in the paint), because they apply too much touch-up paint.
So less is best, move slow, take your time.
