Stone chip painting after waxing
Results 1 to 5 of 5
Thread: Stone chip painting after waxing
    Apr 2007
    US
    1,121
    25
    I waxed my black vehicle this weekend and while doing it in noticed two small stone chips. Unfortunately I had already waxed over the two spots. Can I dab a little black paint on those spots now, or will it not stick because of the wax?
    Should I clean the two spots with varsol, soap/water, then paint, and rewax? The chips are are not into the metal, just the primer is showing.
    Thanks.
    Registered Member erobertson's Avatar
    Dec 2007
    86
    Re: Stone chip paitng after waxing
    I'd certainly clean the chip and a small surrounding area before attempting to apply paint. Isopropyl alcohol, etc will usually do the trick. If you used anything that might contain silicones be especially diligent with your cleaning.
    'Pearly Gates' Eddie6th's Avatar
    May 2009
    Italy
    3,169
    91
    You'll have to clean the spots first to give the touch up paint some good adhesion.Soap alone will not remove wax and the paint will not stick.The surface will need to be grease free.
    I normaly clean the spot with a little diluted alcohol/spirit.
    40
    19,233
    239
    You might want to sand a little as well, to make sure any loose edges are removed.
    Apr 2007
    US
    1,121
    25
    Re: Stone chip painting after waxing
    Thanks all. I appreciate the help.
  1. LANGKA Paint Chip and Scratch Repair
    By Chesney09 in forum Detailing 101
    Last Post: Mar 24th, 2009, 01:12 PM
  2. Power waxing vs. hand waxing
    By Silverbaby in forum Detailing 101
    Last Post: May 16th, 2008, 09:30 PM
  3. Painting and waxing...
    By TrufflePig in forum Detailing 101
    Last Post: Jan 2nd, 2007, 09:55 AM
  4. Help needed with a chip
    By 96greencivic in forum Detailing 101
    Last Post: Aug 4th, 2006, 06:15 AM
  5. Cleaning between painting and first waxing.
    By JCE in forum Detailing 101
    Last Post: Dec 23rd, 2004, 11:50 AM
