I got this "thing" somewhere that is great for cleaning pads, without using a lot of pad cleaning solution.
With the original grit guard, when you want to drop your pads in the bucket to soak the foam pads, you would need at least 4 inches of liquid to have the water level in the bucket high enough to soak the pads. I found this product that uses much less, while trapping polish powder at the bottom. You can probably find it at the kitchen of the dollar store, or something like that.
I know that many people use grit guard during wetsanding, to keep their sandpaper soaked. Again, the problem with that is you have to have a very high water level to adquately soak the sandpaper. This "thing" works great without having to use a lot of soap and water.
It's also shallow so you do not have to reach in to the bucket.
