Properly diluted, is APC+ safe on paint if washed off within a short period of time? Thanks guys!
APC+ on paint?
Re: APC+ on paint?
How do you use it to clean exterior plastics and such? Just spray it on, scrub, then rinse it off, or what?Shane
Re: APC+ on paint?
Originally posted by CieraSL View PostHow do you use it to clean exterior plastics and such? Just spray it on, scrub, then rinse it off, or what?
I've had bad experiences with 10:1 APC on paint, though, so I'll continue to avoid using it.
Any time I use it, wherever it drips, it eats through the wax and leaves semi-permanent drip marks that were only removed with the DA and some M205...not worth my time to use the APC =/.
Or think about how it would look if you sprayed APC on your dashboard, let it run down and dwell for a minute or less, then wiped away the excess. There would now be these extremely stubborn drip marks, where the APC ate thru the coating and dirt. Same idea . Oh, I have APC and APC+, too.
Re: APC+ on paint?
A few detailers on the Mazda forum have been using diluted APC+ on the front bumper, grill, and side skirts before a full detail. It works like a bug remover, it is cheap, and the strength can be controlled to suit different conditions.
However, using APC+ on the paint would noticeably dull the surface. This is why using APC+ as a bug remover is usually done before a full machine polish. A typical bug remover contains an ingredient that prevents paint surface from getting dulled. The APC+ does not.
