Help?>>>
I bought a '99 Ford Ranger for my two high schoolers. One of the reasons I got a decent deal on it, is that it had been attacked with super-glue sometime in the past and, in general, had been used roughly (driven through the bush etc.).
No big deal, I figure - the perfect car to learn a bit about buffing on....?
I've collected some stuff - can someone tell me where to go from here?
So far, I've only begun the hood - and, no doubt, screwed it up a bit. One of the first "remedies" for super glue found on the internet is brake and carb cleaner... - probably ate through some clear coat (and into paint?)... But I trudge on... I used some heavier wet sand paper - 400? 600? - The glue is off... that's where I begin... Should I just keep going with some 1000 and 2000 grit papers?
Then... I bought a buffer (Porter Cable 7424xp) - real pretty thing, but I notice that rpms are 2500-6000 - and I watch the videos here that say 1500 rpm is better...???
I have an assortment of "Lake Country" pads - two terry bonnets - one wool pad - a spur cleaner... and three Meguiars products (#1 medium cut, #2 fine cut, and #9 swirl remover)
What steps from here?...
Thanks!!
Thanks!!
