from now on i will buying mothers clay kits cause it has 2 80g bars in it,with same stuff in it except sample cleaner wax that i already have 5 of,for the same price.and with more clay it is thicker also,so i think meguiars should put bigger bars in there smooth surface clay kits.thanks for reading.
160g clay in smoth surface kit.
Re: 160g clay in smoth surface kit.
I may have to begin picking up the Mother's kit an affordable local clay.James - 1979 Oldsmobile Cutlass Calais
Calais Auto Detailing
CalaisDetails@aim.com
Originally posted by spence82 View Postfrom now on i will buying mothers clay kits cause it has 2 80g bars in it,with same stuff in it except sample cleaner wax that i already have 5 of,for the same price.and with more clay it is thicker also,so i think meguiars should put bigger bars in there smooth surface clay kits.thanks for reading.
Have you tried it yet? How is the clay as far as "sticking" goes? Contaminant cleaning? Is the only upside more clay? What are the overall PROS/CONS of the product?
I like their Back in Black product but only use it because I could never find any Megs Trim Detailer. It's VERY runny but does a good job. The Megs is on my list for an upcoming ADS order since online seems to be the only place to buy it.
Originally posted by Calais View PostI may have to begin picking up the Mother's kit an affordable local clay.
I had the Mother's clay kit once and didn't like it. I used up what I had, but I wouldn't buy it again. I'll stick with the Meg's clay kit. IMO, everything in it is just plain better.Shane
Seen as I'm hardcore Meguiar's user, the replacement kit is about 18 bucks with 3, 50gm bars at ADS......
I like Meguiar's products.
I like the white bars as it's easy to see what comes off and if I need to knead the bar or toss if it's filled up.....
Find something you like and use it often!Philippians 2:14 - Do all things without grumbling or questioning,
Originally posted by Nappers View PostSeen as I'm hardcore Meguiar's user, the replacement kit is about 18 bucks with 3, 50gm bars at ADS......
I did the math. The Smooth Surface Clay Kit available at Walmart for $16 is actually a much better deal than the replacement kit for $18. The full size bottle of Quik Detailer and a Supereme Shine Microfiber Towel makes the kit a much better value than the Meguiar's Clay Refill Kit.
Originally posted by the_invisible View PostI did the math. The Smooth Surface Clay Kit available at Walmart for $16 is actually a much better deal than the replacement kit for $18. The full size bottle of Quik Detailer and a Supereme Shine Microfiber Towel makes the kit a much better value than the Meguiar's Clay Refill Kit.
You're right, but the problem I have using kits is that I always finish using the clay before the QD gets used up. So more and more QD + MF keeps stacking up in my garage.
Originally posted by james0509 View PostYou're right, but the problem I have using kits is that I always finish using the clay before the QD gets used up. So more and more QD + MF keeps stacking up in my garage.
I stick with the Meguiar's.....It's color makes it easy to find the ick that is being pulled off of the paint!Philippians 2:14 - Do all things without grumbling or questioning,
