Planning to purchase the grit guard but is the grit guard one size fits all?
Grit guard
Perhaps in addition to the Grit Guard you can try this tip from Rod Kraft:
Take two 5 gallon buckets
drill small holes in the bottom of one
take that bucket and slip inside the other
Now you have protection against grit contaminating your water
I bet if you couple that with a Grit Guard you'll have some serious protection!
I don't have one either but I'm getting by just fine with this 2 bucket method I mentioned above.
I bet if you couple that with a Grit Guard you'll have some serious protection!Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Yep, that's exactly what I did
I don´t mean to hijack this thread, but I have been looking for a grit guard for a long time. When I read this post today I got a lot of ideas, so I went out looking for something similar to use and this is what I found.[IMG]http://archive.meguiarsonline.com
I think that may go particularly well with the two bucket-one drilled in the bottom inside the other method
