I have a bottle of the Quick Detailer that came with the smooth surface clay kit. How different is this from the last touch, if I wanted to buy a 32oz or gallon?
Last Touch vs. Quick Detailer
Re: Last Touch vs. Quick Detailer
I agree, go with a gallon of Last Touch. It's about $15 for the gallon, which makes 2 gallons of clay lube. Much easier on the wallet than QD. If you want a slick detailer, you can also use LT straight.
Also, M34 (Final Inspection) is the gallon version of QD if you are wanting more of the same product. You cannot dilute it, comes ready to use.NOTE: Post count does not reflect actual detailing knowledge.
I dilute the LT about 1 part distilled water, 2 parts LT, and it works just like QD. I use it in the QD bottle too (which I really like the sprayer on). Overall I'm pretty happy with the LT, especially for the price, given that I go through so much of it living next to a burned mountain which covers the cars in ash/dust every day.
Originally posted by ColonelCash View PostAlso, M34 (Final Inspection) is the gallon version of QD if you are wanting more of the same product. You cannot dilute it, comes ready to use.
Due to the way they are marketed, I was under the impression M34 was somehow a step up from QD.
So the "best" spray on / wipe off cleaner and clay lube is LT?
So the "best" spray on / wipe off cleaner and clay lube is LT?Michael Stoops
I think the M34 is a step-up of QD and M34 Final Inspection is Body Shop safe....
here in Indonesia, detailers choose LT over M34 because the price is cheaper.. :]Ganesa,
Toyota Vios '05
Originally posted by AeroCleanse View PostI am looking at Last Touch, how long does a gallon last? Wondering if I should get a gallon or the 5-gallon.-HealthyCivic
Check out the glossary
Here is the last touch bottle.
Last Touch Bottle
Standard Sprayer
Andy M.Keeping MOL family friendly! If you need help or have a question, don't hesitate to shoot me an email or PM. 101impala@gmail.com
Andy M. Moderator
Originally posted by JohanD View PostOne more question.
Should I get the regular spray nozzle or the foaming spray nozzle?
IMO, go with the regular sprayer. It will produce the mist you're after when QDing. Plus, you can adjust the spray pattern to your liking.Alex C.
Originally posted by Black150 View PostIMO, go with the regular sprayer. It will produce the mist you're after when QDing. Plus, you can adjust the spray pattern to your liking.NOTE: Post count does not reflect actual detailing knowledge.
Originally posted by Michael Stoops View PostSimilar, but not identical. M34 is the only one of our mist & wipe products that is body shop safe, so if you're in an environment where fresh paint is being sprayed and you need a clay lube or something to remove dust on a regular basis, M34 is your product of choice.
