Ultimate Protectant - Page 22
Page 22 of 22 FirstFirst ... 12141516171819202122
Results 211 to 220 of 220
Thread: Ultimate Protectant
  1. #211
    Jan 2009
    New Lenox, Illinois
    10,362
    302
    Re: Ultimate Protectant
    APC can dry out some vinyl and plastic.
    Registered Member Poki's Avatar
    Jul 2008
    U.S.A.
    547
    22
    Not sure just how "much" UV protection 303 has (or just how a consumer would measure it) but UP is highly loaded with UV blockers. Don't get us wrong, we know 303 to be an excellent water based product with a very loyal following - and rightfully so. But looking at the polymers in UP, and how they behave, compared to a typical water based dressing and the protection lasts a crazy long time as well.
    303 does have a great following and I have used it for years....until UP. To me, the big differences are the labor factor and streaking. 303 requires lots and lots of wiping to get it near dry but still streaks for me. UP...wipe on and work it in a bit....done!!
    Barry
  3. #213
    Registered Member music_man185's Avatar
    NC
    116
    12
    can i use quik interior detailer to clean my dash and then apply ultimate protectant over that? or is that overkill if my dash isn't "dirty"
    2007 Toyota Tacoma Double Cab V6 SR5 - Black Sand Pearl
  4. #214
    Jul 2008
    U.S.A.
    547
    22
    Quote Originally Posted by music_man185 View Post
    QID I don't believe is intended to be a cleaner. Also, if you use if before using UP, the UP will not properly bond to the surface you are putting it on. Your best bet is to clean any previously used product from the dash then apply UP.
    Barry
  5. #215
    Detailing BoZo jfelbab's Avatar
    Apr 2004
    Cape Coral, FL
    1,485
    33
    I personally am pleased with the protection and appearance of QID in the interior. I use it on everything including the leather, vinyl and even the LCD panel and gauges. I occasionally use UP on the exterior but have taken to just using UQW over everything on the exterior, vinyl and glass included. I'm not sure I need UP anymore.
    And Poki, QID is a also cleaner.
    The fastest way to clean all interior surfaces. Use every time you wash or Quik Detail your paint to give your interior that “just detailed” look. In just 5 additional minutes, your entire interior will look sharp and smell fresh. Quickly and easily maintains the look and feel of interior plastics, vinyl, leather, rubber, metal and even audio/video equipment. The safe, high lubricity formula lifts off dust, ashes, dirt, grime, spills and fingerprints without build-up. And, unlike traditional protectants that leave an artificial greasy feeling, Quik Interior Detailer leaves your interior™ surfaces looking natural and revitalized. Simply spray on, spread evenly with an Ultra Plush Super Terry or Supreme Shine® Microfiber and turn to a dry section of the towel for the final wipe off.
    Basically, it is a cleaner with UVA/UVB protection.
  6. #216
    NC
    116
    12
    is ultimate protectant safe on paint if i accidentally get some on while applying to exterior trim? i would of course wipe it off immediately, but would that be good enough? or would i need to pull out some UQD or something to fully remove it?
  7. #217
    Registered Member fordf150's Avatar
    Jul 2009
    Hanover Minnesota
    166
    You'll be fine unless maybe you let it dry on there, then it might be a PIA to remove. I usually go along and wipe the edges of the trim that meet the paint after i'm done. You could certainly use a QD you want.
    2019 Ford F-150 XLT SPORT 4X4 Ecoboost
  8. #218
    Nov 2010
    Jakarta DKI
    12
    Hi, can I use this product on my tires too?
  9. #219
    Jul 2009
    Hanover Minnesota
    166
    I think it says for rubber and vinyl, but not sure why you would as there are probably better products for tires. Because of the size of the bottle you probably would be going thru it quite fast for tire use.
    Meguiars makes a whole bunch of tire products that are probably better suited.
  10. #220
    Sep 2005
    Sydney, Australia
    4,313
    66
    Quote Originally Posted by alexh View Post
    You can but it's not all that suited to tires, due to the amount of flex/movement in a tire sidewall. It has been done with some success...
  1. The secret to applying Ultimate Quik Wax
    Last Post: Mar 15th, 2016, 12:07 PM
  2. Ultimate Compound
    By Tuck91 in forum Consumer Line - Product Reviews
    Last Post: Aug 17th, 2011, 06:05 PM
  3. Okay, just one more Ultimate Quik Wax review!
    By Tuck91 in forum Meguiar's Retail/Consumer Line Products
    Last Post: Nov 2nd, 2010, 06:13 PM
  4. Ultimate Quik Wax: It's too easy not to use
    By akimel in forum Consumer Line - Product Reviews
    Last Post: Jul 10th, 2009, 11:49 PM
  5. Help w/NXT Protectant
    By Don in forum Meguiar's Retail/Consumer Line Products
    Last Post: Apr 19th, 2004, 09:01 AM
