Hi MOL,
here iam again with another nice detail that i did for a new Client/Friend, its a Candy apple red Dodge Nitro, after doing another car for him, he wanted to detail this one. it was polished before due to the swilrs i saw in the hood. i had to pick it up from his house he night before to be able to start in the morning working. So heres the post, enjoy relax and shine...
Hola MOL,
aqui estoy otra ves con otro detallado que hise para un nuevo Cliente/Amigo, es una dodge nitro roja. despues de aver trabajado en el auto de su hija, quiso tambien hacer un detallado de esta. Tambien alguien la habia pulido antes por unos hologramas que tenia en el capot. se fue a buscar a su domicilio y despues entregar. Bueno, aqui les va el post, disfruten, relajense y brillen....
Wash/Lavado:
2BM
NXT soap
Microfiber glove
Karcher
California blade
Vroom drying towels
Descon:
Clay lube
Megs Mild Clay
Compund/Compuesto:
Fine wool pad, UC, Rot
Cutting pad, UC, DA
Polishing/Pulido:
Polishing pad, EANW, DA
Sealent:
M21
Extras
Hyper dressing
Detailing brushes
Microfiber cloths
Begining-Comienso
this is how it looked after the wash, not bad from far away, but on close inspection: we had SWIRLS-RIDS-HOLOGRAMS-AND DEEP SCRATCHES.
Asi es como se miraba despues de la lavada, no muy mal de lejos, pero en inspeccion cerca se veian: SWIRLS-RIDS-HOLOGRAMAS-Y RAYAS PROFUNDAS.
2nd Step-2nda Etapa.
rims, tires and suspencion were cleaned one by one with power washer and degreaser with an assortment of brushes.
llantas, ruedas y suspencion fueron lavados uno por uno con la hidro y desengrasante usando una mescla de cepillos.
BEFORE-ANTES
AFTER-DESPUES
The rims were real bad, after cleaning we found black spray paint on them, we were able to remove it after alot of work.
Las llantas estaban super mal, despues de lavarlas encontramos pintura negra.que logramos sacar despues de "MUCHO" trabajo.
on to the polishing, i went to pickup a rotary for this job, to make it go a bit faster, also there were some deep scratches that i opted not to chase to stay on the safe side of the "clear", after this i compounded with the DA to remove holograms. red shirt for red cars.
ahora el pulido, use una rotatoria para comenzar el trabajo, para ir un poco mas rapido tambien, la pintura tenia rayas profundas, al parecer con ramas fuera de camino, asi que decidi sacar los swirls y rayas leves pero no seguir mas profundo para mantenerse seguro con la integridad de la "laca", depues una segunda pasada con la pulidora doble accion para eliminar cualquier holograma. polera roja par autos rojos jeje
(mensaje subliminal?-subliminal message?)
another problem area was the front bumper that was badly painted and has runs in the corners. i went with some 1500 wet sanding to remove the runs and then bring back the shine with compound and polish.
otro problema era el parachoques frontal, que fue muy mal pintado y tenia pintura chorreada en las esquinas. con lija al agua saque lo chorreado y despues a traer el brillo con compuestos y pulimentos.
Before-Antes
After-Despues
the after pics after sealent. las fotos despues de el sellado.
DONEE-LISTO
FAV PIX-FOTO FAVORITA
Delivery-Entrega
Long day work. iam tired, will fo to bed now... byeee
largo dia, estoy cansado, me voy a cama.... chaooo.
-Nelson
Advance Detail Chile
www.advancedetail.webs.com
Hola MOL,
Wash/Lavado:
2BM
NXT soap
Microfiber glove
Karcher
California blade
Vroom drying towels
Descon:
Clay lube
Megs Mild Clay
Compund/Compuesto:
Cutting pad, UC, DA
Polishing/Pulido:
Sealent:
M21
Extras
Hyper dressing
Detailing brushes
Microfiber cloths
Begining-Comienso
BEFORE-ANTES
AFTER-DESPUES
Before-Antes
After-Despues
DONEE-LISTO
Delivery-Entrega
-Nelson
