Let's talk about "Total Cut" - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
Thread: Let's talk about "Total Cut"
  1. #11
    Registered Member 73corvette's Avatar
    Oct 2009
    santee,california
    19
    Re: Let's talk about "Total Cut"
    Quote Originally Posted by Mark Kleis View Post
    I'm really surprised this hasn't gotten more replies...
    This took a tremendous amount of meticulous research and work, and more importantly, it points out some very key concepts to paint correction that are often misunderstood, or missed completely by amateurs just getting started.
    This is the type of guide that is worth getting printed out at Kinkos, laminated, and stuck in your detailing bag to stay with you where ever you go to detail.
    Well done Mr. Stoops!
    Mark
    Truer words were never spoken, if were in this business that is just what I'd do.
    Fact I'm not and I'm still going to do it.
    Rich
  2. #12
    Aug 2009
    florida
    22
    Thanks Mike. Would it be possible for you to comment on this, to help me get a better epectataion of cut. And yes, I'm a consumer and a noob to boot, just trying to get my head around it....
    What would be the total cut difference between the posssible combinations I have to work with this week. And just to make it an easier comparison lets assume equal speed and pressures (while acknowledging that they do have a big effect in themselves)
    Products- UC, SwirlX and 205
    Pads- 8207 and 9207 on a 110
    UC/8207 would be the most cut obviously, and 205/9207 would be the least.
    But what about the other 4 possible combos- where do they fall?
    UC/8207 >Swirlx/8207 >UC/9207 >205/8207 >swirlx/9207 >205/9207 ??? Or how do they stack up/cut down?
    TIA
  3. #13
    21,402
    1138
    Your list from most to least aggressive is pretty much right on the money, but the colored pairs shown below would likely be so close in total cut as to be a wash - depending on the paint you may not notice much of anything between them. Again, this assumes equal speed and pressure.
    UC/8207 >Swirlx/8207 > UC/9207 > 205/8207 > swirlx/9207 >205/9207
    Consider, however, that you'll generally work a polishing pad with a bit more speed and pressure and you might want to reverse the order of the colored pairs. But again, you're kind of splitting hairs. You certainly don't need to do ALL of these steps, but we suspect you already understand that.
  4. #14
    Rasky's Auto Detailing RaskyR1's Avatar
    Dec 2007
    Eden Prairie, MN
    44
    1,920
    200
    Excellent write up Mike!
  5. #15
    Learner HealthyCivic's Avatar
    Sep 2008
    Southern California
    30
    506
    19
    Mike,
    Thanks for the great post. Phillips used to mention all the time how it wasn't just the product, just the pressure, or just the pad that determined the outcome but a combination of all of those things. Your post demonstrated this very well and I can definitely save this to show to the next guy I encounter who's unclear about why he's not getting the results he wanted or expected while using a particular product.
  6. #16
    Registered Member Garage Troll's Avatar
    Jul 2009
    Sinking Spring Pennsylvania
    601
    17
    This is a great write up. So I guess when I get my Soft Buff 2.0 polishing pads I should try some M105 on the deeper clear coat scratches huh? They look like someone rubbed up against the side of the car before I owned it. It wouldn't be such a big deal but since the other side was repainted due to a kid hitting it with a bike it really looks off when looking at it with a flourescent (sic) light.
    Would you guys suggest starting with a slower speed on my PC and lighter pressure and then stepping up to a faster speed and more pressure? I'm getting the feeling that that's the way to go.
  7. #17
    21,402
    1138
    Garage Troll, can you feel any of these deeper scratches with your fingernail? If so, then the best you can generally expect is to perhaps minimize their appearance but you most likely won't get rid of them. If you can not feel them, however, then you should be able to eradicate them.
    Starting with too slow a machine speed when defect correction is the aim generally just ends up with a poor result. If you're finding that a product like SwirlX is doing a great job on all but the most stubborn defects, then step up to Ultimate Compound but keep the machine at the same speed and use the same type of pad. Don't change multiple variables at one time as you won't get a true comparison of the two products.
  8. #18
    Registered Member Kevin Brown's Avatar
    Apr 2004
    692
    457
    Just happened across this thread by way of Mike Phillips' thread about SMAT aggressiveness:
    http://meguiarsonline.com/forums/showthread.php?t=40514
    I think you should make the diagrams on this thread easier to find. These diagrams go a long way towards helping eliminate the confusion that always seems to accompany discussions about aggressiveness, especially when consumer items are compared to professional items.
    Way to go, Stoops!
    Kevin Brown
  9. #19
    May 2005
    55
    15
    Maybe we should let consumers products not to be compared to professional products?
    Therefore less confusions will arise.
    BTW Micheal Stoops, good thread....thanks
  10. #20
    Kinder Car Care Daniel Kinder's Avatar
    Dec 2006
    Paintsville Kentucky
    1,253
    33
    Fantastic thread!
    Thanks for taking the time.
  1. Man, talk about some soft paint!
    By Nick Chapman in forum The Break Room
    Last Post: Apr 24th, 2009, 09:42 AM
  2. Lets talk pneumatic wet sanding...
    By Nick Chapman in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jan 21st, 2008, 12:00 PM
  3. With all the talk of #16, why do I need a can....
    By gb387 in forum Detailing 101
    Last Post: Mar 13th, 2006, 03:36 PM
  4. Tuner Talk????
    By Jorge Sanchez in forum Detailing 101
    Last Post: Aug 25th, 2005, 06:51 AM
  5. Welcome to Tuner Talk!
    By Mike Phillips in forum The Break Room
    Last Post: Mar 28th, 2004, 09:12 AM
