10 Year Old Paint
  • #16
    Re: 10 Year Old Paint
    Final shot
    • #17
      Beautiful job SHYNE! I hope those "earthquakes" over there are not messing you up any!
      Wife say's I'm "obsessed"!
      • #18
        Big Thanks
        No problem with the Quakes I just hold the Buffer still and let the vehicles move around. LOL
        • #19
          Originally posted by SHYNEMAN123 View Post
          Thanks Tim
          Have you found that Ford and Imports Buff up nicer ?
          Do you ever mist over compound ?
          Hey Frank,
          It depends on the import and the year of Ford. I have found that some of the Fords have really hard paint while others are not that bad. Same for imports, some are brutally hard depending on make while others are so soft that breathing on them creates swirls!
          I used to mist the pad with water many years ago with the older products, like M04 etc, but not now. If it is humid, I may add some M34 to the pad to increase buffing time, but generally, the days of using water to increase the cut is pretty much gone with the new SMAT's and modern Diminishing Abrasives....
          Tim
          Tim Lingor's Product Reviews
          • #20
            Big Thanks David.
            Flex rotary CK 603 VE ( It's OLD)
            speed set at about 1200 rpm
            Solo red wool
            105 not enough work time dusting up but cut ok
            86 did not cut as well as 105
            95 cut fine but not the clarity of 105
            3M 6085 I had a little left in the bottle cut & clarity ok
            Went with 105 and misted last touch for final passes
            G110 set on 3 and # 105 with yellow 2.0 pad
            G110 set on 3 and # 80 with yellow 2.0 pad
            G110 set on 2 and # 21 with black 2.0 pad
            LSP 1 12 oz can COOR'S LIGHT for my friend Andy
            LMAO!!!!!!!!!!!
            Andy M. Moderator
            • #21
              Any overall shots of the car?
              • #22
                • #23
                  Nice job.
                  • #24
                    Another incredible restoration, Frank! Thanks for sharing it. If you don't mind, I posted a link to this job of yours in the Spanish forum I once told you about.
                    Regards
                    • #25
                      Regards
                      Thanks
                      And I am honored
                      • #26
                        Why such slow speeds with the 105 and 80 steps? By the looks of the vehicle (Great Job!!!), I might need to slow down my machine.
                        • #27
                          With 105 just trying to give it more work time and with 80 you can bump it up a notch or two but I like the look of the tight pattern and results and at my age I am not in a hurry anymore.
                          • #28
                            i would only say
                            you are wiser & we need to take heed & learn from your rich experience
                            speed is not the matter...we are not keanu reeve
                            results does...thanks for sharing this tips
                            • #29
                              Nice job Frank. Gotta love that 80 Bro.
                              • #30
                                Awesome job
                                Schotography
