Ungrit Sanding Discs & Finishing Discs
Results 1 to 10 of 16
Thread: Ungrit Sanding Discs & Finishing Discs
    21,402
    1138
    *** New Products for 2010 ***
    Ungrit Premium Professional Finishing System – DA Application
    DA – Sanding Disc vs Finishing Disc
    “Sanding” Disc
    • Sanding = No foam backing (commonly called a “film” disc)
    • Designed to level texture or remove heavy surface defects
    “Finishing” Disc
    • Finishing = Specialized foam backing (commonly called a “foam” disc)
    • Designed to refine sanding marks & remove light to moderate surface defects
    In the image below you can clearly see the specialized foam backing on the finishing disc on the left. The disc on the right is a sanding disc of the same grit - notice the lack of a foam backing, hence the common term "film" disc.
    Advantages to DA Sanding/Finishing
    • Faster = More profitable
    • More uniform / consistent = less buffing time
    • Less fatigue
    • More material cost, less labor costs
    _________________________________________________________________________________________
    Sanding Disc Product Attributes:
    • Precise, uniform grit particles for a smooth and even sanding pattern
    • Ideal for removal of dirt, orange peel and severe paint defects on fresh finishes
    • Quickly levels texture
    • Micro hook / loop attachment system
    <table border="0" width="540"><tbody><tr><td class="style18" width="45">
    Grit
    </td><td class="style18" width="68">
    Part #
    </td><td class="style18" width="147">
    Disc Type
    </td><td class="style18" width="56">
    Size
    </td><td class="style18" width="97">
    Qty/Box
    MSRP
    </td></tr><tr><td class="style18">
    320
    </td><td class="style18">
    S3320
    Sanding (dry)
    3”
    50
    $11.88
    500
    S3500
    Sanding (dry)
    3”
    50
    $11.88
    800
    S3800
    Sanding (dry)
    3”
    50
    $11.88
    1500
    S31500
    Sanding (damp)
    3”
    25
    $32.92
    1500
    S61500
    Sanding (damp)
    6”
    25
    $65.32
    </td></tr></tbody></table>
    NOTE: 3” size are designed for headlight and spot repair system,
    6” size are designed for full panel / vehicle repair
    Foam Finishing Disc Product Attributes:
    • Precise, uniform grit particles for a smooth and even sanding pattern that buffs out in seconds
    • Finishing = specialized foam backing
    • Quickly refines sanding marks & removes moderate surface defects
    • Soft foam backed disc for texture matching and scratch refinement
    • Always used damp (water only - no sanding lube)
    Grit
    Part #
    Disc Type
    Size
    Qty/Box
    MSRP
    </td></tr><tr><td>
    1000
    </td><td>
    S3F1000
    </td><td>
    Finishing
    </td><td>
    3"
    </td><td>
    15
    </td><td>
    $46.28
    </td></tr><tr><td>
    1500
    </td><td>
    S6F1500
    </td><td>
    Finishing
    </td><td>
    6”
    </td><td>
    15
    </td><td>
    $96.14
    </td></tr><tr><td>
    3000
    </td><td>
    S3F3000
    </td><td>
    Finishing
    </td><td>
    3”
    </td><td>
    15
    </td><td>
    $48.53
    </td></tr><tr><td>
    3000
    </td><td>
    S6F3000
    </td><td>
    Finishing
    </td><td>
    6”
    </td><td>
    15
    </td><td>
    $96.14
    Registered Member SHYNEMAN123's Avatar
    Jun 2008
    DILLSBURG PA.
    58
    1,303
    782
    Re: Ungrit Sanding Discs & Finishing Discs
    I love that Uni-grit is expanding the product for D/A use but the pricing seems high.
    Jun 2008
    DILLSBURG PA.
    58
    1,303
    782
    For example 3M 6" 3000 grit is only 4.95 per disc Trizact and Mirka is even lower yet.
    I fully understand the diff with Uni-grit techno but from a marketing stand point I would have the pricing could be closer. JMHO
    Rasky's Auto Detailing RaskyR1's Avatar
    Dec 2007
    Eden Prairie, MN
    45
    1,920
    200
    Very Cool!
    21,402
    1138
    Quote Originally Posted by SHYNEMAN123 View Post
    Your feedback is greatly appreciated, Frank, but keep in mind these are MSRP prices so street pricing could potentially be lower depending on your source.
    Jun 2008
    DILLSBURG PA.
    58
    1,303
    782
    Yea I do get pretty $ from my supplier. I was hoping Uni Grit would come out with some new products Especially with 3M's patent on 3000 grit expired so that should help with pricing as well.
    I do love the uniformity cut with Uni Grit.
    Mar 2010
    Lansing, Michigan
    203
    Anyone know if there's a source that has these in stock? I haven't seen them from ADS, Autogeek, etc. at all, but I do see them posted with prices and showing "ships within 1 day" availability at detailing.com -- and I've never dealt with that particular supplier so I don't know whether or not to trust it....
    Learning True Art of Detailing TimG's Avatar
    Apr 2008
    Borneo - Mount Kinabalu
    1,802
    48
    Same here. Saw one seller on ebay selling the said product. I ended up buying a few boxes of 1500 & 3000 grit from 3M.
    21,402
    1138
    These are just now starting to ship so it may still be a couple of weeks or so before you find them in stores or even at online sellers.
    Mar 2010
    Lansing, Michigan
    203
    Awesome.... thanks!
    I figured the guys advertising that they have them already were full of it....
  1. Meguiars #205 - The Ultimate Finishing Polish? My Thoughts
    By Kickin Griffin in forum Professional Line - Product Reviews
    Last Post: Aug 4th, 2010, 04:44 PM
  2. Single Stage Paint Wet Sanding Finishing
    By Zaboss in forum Detailing 101
    Last Post: Oct 9th, 2008, 06:51 AM
  3. color sanding and all that good stuff by hand
    By tomsteve in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Oct 6th, 2008, 09:43 AM
  4. Cyclo with sanding discs?
    By oldmodman in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jan 6th, 2008, 03:49 PM
  5. 6" Hook and Loop Uni-Grit sanding discs
    By detailbarn in forum New Product Suggestions
    Last Post: Dec 1st, 2004, 03:31 PM
