Ungrit Sanding Discs & Finishing Discs - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Ungrit Sanding Discs & Finishing Discs
  1. #11
    Rasky's Auto Detailing RaskyR1's Avatar
    Dec 2007
    Eden Prairie, MN
    46
    1,920
    201
    Re: Ungrit Sanding Discs & Finishing Discs
    Mike do you know if the Velcro on these disks is the same as the 3M? I already have the 3M interface pads and just wanted to know if it will work with the Megs disk or if I have to order the Megs interface as well.
    Thanks,
    Rasky
  2. #12
    21,405
    1140
    Rasky, as long as you have 3M's "Hookit" system and not their "Hookit II" system you'll be fine. Their "Hookit" backing plate is a bit harder than ours, too, just so you know.
  3. #13
    Dec 2007
    Eden Prairie, MN
    46
    1,920
    201
    Looks like I have another order to place....
    Thanks Mike!
  4. #14
    Jan 2008
    6
    14
    I better be asking the most qualified. When we use such discs, what pressure do we put on the panel? Is the weight of the polisher sufficient? I use the Flex DA. Many thanks.
  5. #15
    21,405
    1140
    Quote Originally Posted by Keefe View Post
    Downward pressure should be no more than the weight of the machine itself - you are simply guiding the tool and letting the sanding or finishing disc do it's job. Pressure causes the abrasive disc to cut too fast and too deep. Very light but uniform pressure coupled with smooth and relatively fast passes will yield a very refined and predictable sanding scratch that will be easy to buff out, and it will also prolong the life of the disc. In fact, when done properly, a single 3000 grit foam backed finishing disc can be used for defect correction on an entire full sized car, perhaps more.
  6. #16
    Jan 2008
    6
    14
    Thanks so much! And the reply is QUICK!! Hmm... guess the hardest thing now is to maintain that kind of pressure on the vertical panels.
  1. Meguiars #205 - The Ultimate Finishing Polish? My Thoughts
    By Kickin Griffin in forum Professional Line - Product Reviews
    Last Post: Aug 4th, 2010, 04:44 PM
  2. Single Stage Paint Wet Sanding Finishing
    By Zaboss in forum Detailing 101
    Last Post: Oct 9th, 2008, 06:51 AM
  3. color sanding and all that good stuff by hand
    By tomsteve in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Oct 6th, 2008, 09:43 AM
  4. Cyclo with sanding discs?
    By oldmodman in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jan 6th, 2008, 03:49 PM
  5. 6" Hook and Loop Uni-Grit sanding discs
    By detailbarn in forum New Product Suggestions
    Last Post: Dec 1st, 2004, 03:31 PM
