Premium Professional Finishing System Backing Plates
  • Premium Professional Finishing System Backing Plates
    *** New Products for 2010 ***
    6” DA (air or electric) - Sanding
    3” DA or Rotary for “mini tools” - Sanding or Polishing
    3” Rotary (Full size) - Polishing
    Product Attributes:
    • Distributes pressure for smoother sanding / finishing
    • Precisely tuned outer edge for ideal disc contouring over flat and curved surfaces
    • Allows quick disc changes with micro hook / loop attachment system
    • Part #:
      • S6BP – 6” DA (air or electric)
      • S3BP – 3” DA or rotary for “mini tools” (incl. adapters)
      • W63 – 3” rotary (5/8” arbor)
    • MSRP:
      • S6BP – $34.25
      • S3BP – $24.93
      • W63 – $14.99
    Re: Premium Professional Finishing System Backing Plates
    Any pics of the other side and an iso view?
      We can get pix of the flip side, but it's just a hook & loop face.
        Can you tell us exactly what will be available and when each of these products will be available?
          Sorry, we don't have totally firm in stock dates on some of these items yet, but these should be available late December.
            obviously needed with new pads lol
            Zach Hall
              The 3" backing plate (S3BP) will include both adapters for use with the rotary and/or the DA?
              Brian
                Yes, you'll be ready to run with both tools.
                In fact, this just in:
                Here's what comes with each S3BP 3" backing plate:
                5/16-24 EXT Adaptor Set
                • ¼-20 Ext x 5/16-24 Ext
                • ¼-20 Int x 5/16-24 Ext
                • ¼-28 Ext x 5/16-24 Ext
                • 5/16-24 Ext x 5/16-24
                • 5/16-24 Ext x M6-1.0 Ext
                For any of you who might be using a Cyclo Polisher, purchasing 2 of the S3BP backing plates with adaptor kits will enable use of the Cyclo Polisher (using their upgraded weight kit). Pretty cool, huh?
                  It comes with all of those adapters, Wow.
                  Do you have pictures of them or can you tell us what each of them are for? I'm not exactly sure which one is for what. I know the G100 is 5/16" thread, but I see a bunch of 5/16" listed above. Is one of those adapters for use with a drill if we do not happen to have a mini rotary?
                  Brian
                    The new backing plates look good. Can't wait to try them out.
                      Looking at the list, I am guessing that the 5/16-24 Ext x 5/16-24 is for the DA? I do not see a 5/8" size for the rotary however, and I am not sure what the 1/4" and M6 sizes would be used for? I'm guessing maybe those small sizes may fit the air tools?
                      Brian
                        Yes, that's correct. When using a standard rotary buffer with a 5/8" arbor you would select the W63 rotary backing plate (third image down in the original post of this thread).
                          OK I understand now.
                          I was confused at first because I originally asked if the S3BP would be able to be used on both the DA and the rotary with the included adapters and you said yes. I see now that it is for use with the DA and mini rotary, not the standard rotary.
                          I got it now, thanks. Sorry for the confusion.
                          Brian
                            Hey Guys,
                            If you want to use the Spot Repair Pads with the 5/8" Rotary, you will use the Rotary Backing Plate W63. We have done extensive testing with the Cyclo set up with the S3BP and new counter balance system yielding excellent performance.
                            Do it right the first time
