Have you guys ever tried this? I heard the industrial hand cleaner that you can get in little bottles that has pumice that removes oils from your hands does a good job at de-greasing tires. Is this truth or garbage?
Hand de-greaser used to clean tires?
Re: Hand de-greaser used to clean tires?
u mean hand cleaners like fast orange and gojo ? i dont know how well it would work but its not worth it to spend money on that to clean ur tires..works great on hands but dont spend money on it to clean ur tires...to get the greasiness off my tires i use any household degreaser like 409 and stuffAddicted
Originally posted by Tuck91 View PostSwirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
Originally posted by paudashlake View PostWoW! Where did all of that come from?!?Nick
I use Westley's Bleche-Wite, at ~$4/bottle you reall can't go wrong. With a good scrubbing it makes even the most funk covered tire look beautifully clean.James - 1979 Oldsmobile Cutlass Calais
Calais Auto Detailing
CalaisDetails@aim.com
Originally posted by Calais View PostI use Westley's Bleche-Wite, at ~$4/bottle you reall can't go wrong. With a good scrubbing it makes even the most funk covered tire look beautifully clean.Nick
They sell 64oz'ers for $6.50; dillutable or not, that is a great price!James - 1979 Oldsmobile Cutlass Calais
I still question if people should be so aggressive in removing everything off of a tire. Where is all of this junk coming from and why is it sticking to the tire? Perhaps from over treating the tire to start with?
Tire flex and this releases anti-ozonants onto the sidewalls in order to protect the tire. I'm sure harsh cleaning removes this protective layer. Now I'm guessing the tire treatments add some ozone protection back to the tire but how much and is this better then just keeping the tire clean?
http://www.conti-online.com/generato..._ozone_en.html
The junk is coming from build up tire shine products. Gels are a major offender of this, since they're thicker and stick on longer, and some people layer tire gels instead of cleaning them with a brush. They think that simply taking a wash cloth or mitt over the tires to get the dirt off is good enough. While getting the dirt off may work, the gel is still on the tire. And some products have silicone in them, which turns rubber brown over time, hence the brown running off of Tuck91's tires.-Kyle
Originally posted by ziggo99 View PostThe junk is coming from build up tire shine products. Gels are a major offender of this, since they're thicker and stick on longer, and some people layer tire gels instead of cleaning them with a brush. They think that simply taking a wash cloth or mitt over the tires to get the dirt off is good enough. While getting the dirt off may work, the gel is still on the tire. And some products have silicone in them, which turns rubber brown over time, hence the brown running off of Tuck91's tires.
thanksGanesa,
Toyota Vios '05
Morning,
When a tire turns brown, it is called "blooming" in which case the anti-ozone additives start to wick to the surface of the rubber. Dressings etc will make a tire dirty as they will attract dirt and hold it there making a goo slurry, but the actual browning is from these anti-ozone additives.
Tim
What I do, and I'm not saying its correct, is to clean the tire with car wash. If it's very dirty I'll spray it down with 7:1 APC, brush is lightly, and then hose it off. I'll either use 301 or Supreme Shine as a dressing. One reason I like SS is that the sprayer just sends a light mist. 2-3 sprays and I move it around with a foam applicator. As mentioned, I stay away from gels and the like as I feel they just gunk up the tire. I've also never had an issue with "sling" as everyone comments on. I think this is because I tend to use very little product on the tire.
Just a few thoughts.
