What method(s) have you used in the past to combat hard water spots? - Page 3
View Poll Results: What method(s) have you used in the past to combat hard water spots
Voters
397. You may not vote on this poll
  • Use a water filter
    58 14.61%
  • Wash only in the morning or in the evening, never when the sun is out
    157 39.55%
  • Use another chemical product after you are done washing to remove spots
    54 13.60%
  • Use a special car wash meant to reduce hard water spots
    58 14.61%
  • Wash car in the shade and dry it off quickly
    281 70.78%
Multiple Choice Poll.
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
Thread: What method(s) have you used in the past to combat hard water spots?
  1. #21
    Registered Member RamAirV1's Avatar
    1,990
    37
    How long has the Quik Wax been on the market? I have never seen it locally. Is a liquid (like #50 or Flagship) required for a base before using this?
    RamAirV1
  2. #22
    Registered Member TKDDAD's Avatar
    May 2005
    Buffalo, New York
    1,023
    25
    Unhappy But what if you can't dry it ???
    I don't see washing a car as troublesome as having it rain and then having the rain dry on your car....many times that happens and you just can't get out to dry it off....result?, ugly water spots !!...I find I get water spots that way and never from washing the car...if you can dry it off, you shouldn't get water spots from washing....so, now the question is what do you do after it rains ???
    Bill Poirier
    West Seneca, NY 14224
  3. #23
    Aug 2005
    20
    15
    i try to wash in the shade and dry as fast as i can. with the texas heat its hard to find a good time to wash when its not to warm/hot esp in the texas summers. for that reason shade works the best. i do try to wash in the mornings and evenings also.
  4. #24
    Registered Member mh68's Avatar
    Jun 2006
    227
    16
    I'm not exactly sure what to select. I have a water softener and use soft water to wash with. Even if it dries before I can dry it off the few spots left behind wipe right off.
    Mike
  5. #25
    May 2006
    48
    14
    A long time ago I bought a bottle of gold class wax, and it had a vidio packaged with it on car care. One little tip that I got from it is that when you are ready for the final rinse. Do not spray the car. Instead turn the water to a low stream, and starting at the top letting it flow creating a sheeting action. I do the top, then hood, then bumper, then working down one side until I get to the trunk, then back bumper, and down the final side. This rinse action doesn't let the water bead as much. So fewer spots, and takes less time, and fewer MF towels to dry.
    If I do have any spots I will hit it with QD. That is why I voted other product to remove spots. Hope this helps.
    The Fox
  6. #26
    Dec 2004
    46
    15
    I've got a whole house softener with well water, the system still leaves plenty of minerals, so I usea all of the methods shown. Megs branf filter would be great.
  7. #27
    Registered Member acsuppa's Avatar
    Nov 2004
    518
    20
    Re: What method(s) have you used in the past to combat hard water spots?
    My vote was: Wash car in the shade and dry it off quickly. I some times will park my car WAY in the back yard and connect my teo long hoses together just for shade. I then quickly knock off the bulk of the water with my Cali Blade then towel dry.
  8. #28
    Registered Member captaincog's Avatar
    Jul 2006
    63
    14
    I have used the other brands of water filters/soap in the dispenser and they always seemed to leave a film, along with the water spots.
    I now use the 2 bucket system, grit guards, and NXT wash, followed by drying.
    Last month I won a raffle with a different brand of car wash and decided to try it on my company car to see if there was a difference in the way I wash now or is the the car wash product itself.
    I have been teaching my kids on how to detail, at least the little amount that I know, and we went through our normal routine: 2 buckets, early evening, no direct sunlight, dry off.
    Worked on some other cleaning tasks and cam back to see....water spots all over!
    I used to be convinced that it was the way I used to wash, which some was, and the hard water that I have.
    It turned out to be the car wash.
    We waited a couple of days and did the same test, same time and weather conditions. The NXT wash produced no spotting.
    I will never use another product.....unless I don't like the person...
  9. #29
    Jan 2009
    Prairieville Louisiana
    I wash in the shade only and then use a combination of leaf blower and enough microfiber cloths to enable me to dry the car quickly. The leaf blower is good for blowing the majority of the water from the large upper surfaces and also from the tight areas with nameplates that can't be reached with a squeege. It can also get most of the water from out of the body panel openings so that there will be less time waiting for the drips to stop. I finish off with microfiber cloths. Good Tip: But a towel wringer and attach it to a bucket or strong plastic box. Put clean rinse water in the container with just a little bit of car wash to rinse and soak your cloths as you finish using them. Run them through the wringer and hang up to dry. I used tio hand wring but it was hard on the towels and not good for arthritic joints of the hands.
  10. #30
    'Pearly Gates' Eddie6th's Avatar
    May 2009
    Italy
    3,169
    90
    I try to get the drying done as quickly as I can,sometimes with help of another person.
    On the black car,it's noticable. On my civic which is met.blue,it's hardly noticable,but they are obviously there just the same.
    I like the hose attatchments,but find they are too expensive.The harder the water,the quicker they will become exhausted.I'd go through too many to make it economically viable.
    I think my answer is to get a water magnet or a bigger chamois.
  1. Hard water Spots
    By NavyJay007 in forum Detailing 101
    Last Post: Dec 4th, 2008, 07:24 AM
  2. Hard Water Spots
    By dgriffin3 in forum Detailing 101
    Last Post: Feb 17th, 2007, 08:18 PM
  3. Hard Water Spots
    By Rut Ro in forum Detailing 101
    Last Post: Sep 30th, 2006, 08:50 AM
  4. Hard Water Spots
    By minorthreat98 in forum Detailing 101
    Last Post: Jun 29th, 2006, 02:47 PM
  5. Hard Water Spots
    By simonjo2 in forum Pictures from Meguiar's Training Garage - Intro to Paint Care & D/A Polishing Classes
    Last Post: Aug 22nd, 2005, 03:43 PM
