Product, Pad & Speed Recommendations for Rotary Buffing
This is a sticky topic.
  • Product, Pad & Speed Recommendations for Rotary Buffing
    We've updated this chart to reflect some of our newer products, and also to include application of rotary compatible waxes. Keep in mind that it's rare to find someone actually applying a wax via rotary, but it can be done provided you use the right products, pads, speed, etc.
    The above reference chart does not mean to imply that you can never stray from these recommendations. Sometimes experimentation yields surprising results, but those results may not be consistent from vehicle to vehicle, paint to paint.
    It should further be noted that M86 So1o Cut & Polish Cream is not on this list because it is system unto itself, including the various pads and dedicated backing plate.
    Re: Product, Pad & Speed Recommendations for Rotary Buffing
    Great chart, Mike! Would D151 fit in the same range as M66?
      Wouldn't you know it..... .... had a funny feeling something would be forgotten! Hang on a minute or three and we'll get D151 added in, but it's pretty unique and can be used with almost any pad.
        Success! Thanks, Mike!
          Not to pee on your shoe and tell you it's raining but could you please squeeze in SOLO #86 as well ? I use it a lot and Love it.
          Thanks Mike
            Thanks Mike
            "It should further be noted that M86 So1o Cut & Polish Cream is not on this list because it is system unto itself, including the various pads and dedicated backing plate." - from original post
                Well thanks to 12 yrs of readen an riten eye figerd tat out wen it 1st hit te market I was looking for any other Meguiar's test info with diff machine/ pad combos and recommendations . LOL
                But I guess I will just do my own
                  Thinking of experimenting with rotary buffer on a wrecked car.
                  I intend to useMedium Cut Cleaner.
                  My rotary has a minimum of 1500 Rpm's, so from 1500 - 6500.
                  Suggestions please.
                  Thanks
                    Hi,i have Meguiars Foam cutting pad and Foam Polishing pad, local made backing plate, i am using Diamond Cut 2.0 with foam cutting pad and branded rotary buffer with local brand backing pad, i could not polish properly, while polishing with diamond cut and foam cutting pad, the polisher gets slips..i mean the polishing pad doesnt rotate firmly on the surface...is it because of non-branded backing pad..do i need to use flexible backing pad or rubber pad.. i hope you understood my problem...requesting you to help me in this case..ThanksNilesh
                      could you add ultimate compound and ultimate polish to this list please so i know the relevant speed to use for my rotary with these 2 products and also which pads thank you
                        Please add M100 or M101 or M105
