I'm looking into purchasing a little green machine. I see there are a few different models. Could someone give their feedback on this unit, also, which model is best for auto interior care. Thanks
Re: little green machine
Originally posted by ziggo99 View PostI don't see a difference between the Pro Heat and Pro Heat Auto, besides price. I found a refurb for around $55 with a google search. Some people like them, some don't.There's no reason to become alarmed, and we hope you'll enjoy the rest of your flight. By the way, is there anyone on board who knows how to fly a plane?
I used my wife's regualr LGM on her upholstery and the resutls were mixed for me. The mats and upholstery did clean up somewhat, but getting a feel for this machine was tricky. By that I mean knowing how much solution to use and learning how to aim the srpayer head so as to get the areas you're trying to clean.
I was not overly impressed with the suction power of the machine. I feel that it left too much behind and the seats were way too wet for me. Now, I admit that part of that could stem from the fact that this is the first (and only) time I'd used the machine.
If you decide to go this route, I would suggest using a separate spray bottle for your cleaner and simply using the LGM to draw up the water as you will have more control over the spray this way.
As a second option, if you have not yet made your purchase, check out the Rigid wet/dry vacs at Home Depot. They have a compact 5HP model that is supposed to do a great job on upholstery and carpet. I just bought one yesterday and have not had a chance to use it for upholstery yet but based on the pictures I've seen of people's work who use the 5hp for this purpose, I am excited about the prospects.
I guess using some APC, a brush and the wet/dry vac would work as I do have a rigid from Home Depot. I currently use a Bissel steamer vacuum, which is like an upright vacuum. It works pretty well. I just like the idea of one of these units that heat the water, just sounds like it would work a bit more effectively if the water was hot, not just warm from the tap. I just don't do enough cleaning to warrant spending $600 on a proffesional grade one. Thanks for the info.There's no reason to become alarmed, and we hope you'll enjoy the rest of your flight. By the way, is there anyone on board who knows how to fly a plane?
I've never actually tried this, but I have seen some of the heaters on ebay for $10-$20 and it seems like it might work well and want to give it a shot.
Its a great little unit for us shade tree detailers but on a larger scale its by all means not enough. Works great in the house also!Current Jeep: 2004 Jeep Liberty with stuff
Originally posted by Mike PhillipsLive on the edge... try something new, try NXT Tech Wax 2
