I recently tried the Dupli-Color 2in1 Premium scratch fix kit and I oversanded pretty bad on the last step while sanding the clear coat. The area where the scratch was looks perfect but there are two areas about the size of a nickel above and below the repair area that have been worn through to the primer and the area is smooth! I was going to try to add some touch up paint and clear coat. Any other ideas? I can provide a picture if this helps
