In my testing a rotary and wool pad with a compound or single polish type product removes 3.8 to 4 microns at 1000 to 1200 rpm then backing down to 600 using light pressure then none
microfibre between 0.5 and 4 microns using a DA
i prefer to go via microns rather than mills
hope this helps
hope this helps
DO you know what the conversion is from microns to mills? It would help all of us non-metric guys
Don
12/27/2015
"Darth Camaro"
2013 Camaro ... triple black
323 hp V6, 6 speed manual
I finished the area off with DACP applied with a DA then topped off the finish with NXT. My final reading was still 3.9. The total mils of clear removed are .3, well within the “safety zone�.
I understand that many variables can play apart in the readings I got. The same procedures performed to another vehicle may not remove as much material or possibly more.
Things such as paint hardness, pressure applied to the finish while I buffed, the number of passes with each product, etc, all come into play. But this little test hopefully will give you an idea what is going on to repair a defect in the finish.
Now it is time to clean up the mess. I made.
So the only thing that took of any clearcoat was sanding,
