How much paint are you removing.
  • #91
    Re: How much paint are you removing.
    Wow! A blast from the past! Still relevant.
    • #92
      In my testing a rotary and wool pad with a compound or single polish type product removes 3.8 to 4 microns at 1000 to 1200 rpm then backing down to 600 using light pressure then none
      microfibre between 0.5 and 4 microns using a DA
      i prefer to go via microns rather than mills
      hope this helps
      • #93
        hope this helps
        DO you know what the conversion is from microns to mills? It would help all of us non-metric guys
        Don
        12/27/2015
        "Darth Camaro"
        2013 Camaro ... triple black
        323 hp V6, 6 speed manual
        • #94
          Micron equals .001 of a millimeter.
          Bill
          • #95
            Bill
            Thanks, trying to figure it out made my brain melt.
            Don
            12/27/2015
            "Darth Camaro"
            • #96
              Originally posted by Superior Shine View Post
              I finished the area off with DACP applied with a DA then topped off the finish with NXT. My final reading was still 3.9. The total mils of clear removed are .3, well within the “safety zone�.
              I understand that many variables can play apart in the readings I got. The same procedures performed to another vehicle may not remove as much material or possibly more.
              Things such as paint hardness, pressure applied to the finish while I buffed, the number of passes with each product, etc, all come into play. But this little test hopefully will give you an idea what is going on to repair a defect in the finish.
              Now it is time to clean up the mess. I made.
              So the only thing that took of any clearcoat was sanding,
