My "rustoleum $50 roll-on paint job"
Page 1 of 18 12345678911 ... LastLast
Results 1 to 10 of 173
Thread: My "rustoleum $50 roll-on paint job"
    Armed w/105 and dangerous InfiniteDetail's Avatar
    Apr 2008
    Arizona
    1,047
    117
    Thumbs up My "rustoleum $50 roll-on paint job"
    Well it finally happened - the hood of my mustang which I used to learn the rotary on finally oxidized so badly I had to do something.
    Hot Rod magazine did an article on how to paint your car with Rustoleum and a foam roller...so I thought I'd give it a try! With Gloss Black (what did I get myself into???)
    Here's what I started with:
    Here was my process:
    • Wash hood with hot water, powdered Tide, and a red scotch brite pad
    • Sand with 80 grit disc on PC to remove most of the layers of old paint
    • Sand with 220 grit disc on PC
    • Sand with 320 grit disc on PC
    • Prime with Rustoleum automotive spray primer
    • Sand with 320 grit using palm sander
    • Prime again
    • Sand again with 320 grit
    • Applied rustoleum mixed 50/50 with mineral spirits using a high density foam roller (2 coats, 12 hours apart)
    • Sanded with 600 grid and Meg's foam block
    • 2 more coats, sanded again
    • 2 more coats
    • wetsanded with Meg's foam block and 1500 unigrit
    • wetsanded with Megs foam block and 2500 unigrit
    • Compounded with PC, 5.5" LC yellow foam pad and M105 (2 passes)
    • Final polished with PC, 5.5" LC green pad and M205
    Whew! Sounds like a lot but doesn't really seem like that much work.
    here's the final result:
    Not too shabby for an amateur painter, a foam roller, and $75 worth supplies (still enough left over for the rest of the car!)
    Thanks for looking
    Jan 2010
    31
    9
    Re: My "rustoleum $50 roll-on paint job"
    Sitting with mouth open. WOW Grrrrrrreat job.
    Detailing Enthusiast seech's Avatar
    Mar 2007
    Kuala Lumpur, Malaysia
    257
    473
    You have GOT to be KIDDING!!! Amazing.... must give this a try someday.
    KC thedetailers KC's's Avatar
    Jul 2009
    kuala lumpur Malaysia
    1,610
    525
    kidding me. .....i want to learn how u did it.....thanks for posting
    amazingly finished
    Registered Member THE BIG BUFFER's Avatar
    Jul 2006
    347
    16
    Wow! Wow! Wow!
    That "thing" in my avatar is painted with rustolem but does not look anywhere near as good as that. Awsome job man.
    Professional Automotive Reconditioning Services
    "You scuff it-I buff it!"
    Apr 2008
    Arizona
    1,047
    117
    Quote Originally Posted by flakybear View Post
    Thanks
    Apr 2008
    Arizona
    1,047
    117
    Quote Originally Posted by seech View Post
    I would recommend it for daily drivers or cars with dead paint. Can't beat the price! It's pretty easy to do as well. I wish I had an air DA sander for the wet sanding, but that wasn't too bad either. Give it a try, you've got nothing to lose
    Apr 2008
    Arizona
    1,047
    117
    Quote Originally Posted by KC's View Post
    amazingly finished
    I used these 2 websites as a guide:
    http://www.rickwrench.com/index79mas...llarpaint.html
    http://www.hotrod.com/techarticles/b...job/index.html
    I say go for it!
    Apr 2008
    Arizona
    1,047
    117
    Quote Originally Posted by THE BIG BUFFER View Post
    Wow! Wow! Wow!
    Thanks Wetsanding with Meg's Unigrit and then compounding with M105 followed by polishing with M205 makes all the difference.
    I realized in my paint correction work that I could make any paint look good as long as there's enough paint to work with.
    Registered Member FIREBOY's Avatar
    Nov 2009
    WESTMILFORD NEWJERSEY
    22
    9
    Great job
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Wet-sanding - Fresh Paint vs Factory Paint
    By Mike Phillips in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Sep 15th, 2011, 06:39 AM
  2. What is the meaning of soft paint?
    Last Post: Jan 23rd, 2009, 10:23 PM
  3. Some newb qns
    By top_cat87 in forum Detailing 101
    Last Post: May 26th, 2006, 09:47 AM
  4. whats the difference
    By bjayjr5679 in forum Detailing 101
    Last Post: May 22nd, 2006, 06:27 PM
  5. Claying im stuck ??
    By WhiteCamaro88 in forum Detailing 101
    Last Post: Jun 21st, 2005, 02:03 PM
