The Aggressiveness Order of SMAT Products - This might surprise you! - Page 4
Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 78
Thread: The Aggressiveness Order of SMAT Products - This might surprise you!
  1. #31
    39
    19,107
    237
    Re: The Aggressiveness Order of SMAT Products - This might surprise you!
    I would guess SwirlX-ish...
  2. #32
    21,401
    1137
    Quote Originally Posted by jdavis92 View Post
    All things being equal...where would White Wax slot in?
    That's a pretty good guess, but it's actually more on par with D151 PRC, all things being equal (pad, tool, speed, pressure, etc).
  3. #33
    Sep 2005
    Sydney, Australia
    4,289
    64
    Wow, really?
    So Mike are you saying that WW has about the same cutting ability as D151?
  4. #34
    21,401
    1137
    Wow, really?
    Yes. White Wax uses SMAT abrasives and is surprisingly effective at removing light to moderate swirls when applied with a DA and a foam polishing pad. Below are a couple examples of the power of White Wax taken from a couple of TNOG sessions early last year. This first one is a great example of swirl removal using WW as a one step product.
    People have asked if they could use the cleaning ability of White Wax on a darker colored car. Well sure you can! Remember, this new White Wax is essentially a cleaner wax that uses SMAT abrasives, so it's got a lot of cleaning power. Here's a before shot of some swirled blue paint.
    One application of White Wax and the swirls are almost completely gone. No, it's not a substitute for a full, dedicated paint cleaner like Ultimate Compound, but for a one step this is a huge result!
    This is more of what WW was designed for: bringing back the true brightness of color on lighter colored vehicles that have been exposed to the elements for some time. You'll notice in the 50/50 shot below that the "before" section actually looked pretty glossy, but it just wasn't "white" any more. With a somewhat aggressive application of WW the brilliance of the white paint is restored - in a single step.
    We're using the yellow foam pad to get a bit more cut, and we're running at speed 5. Normally you'd apply wax with a finishing pad at speed 3, but this is a fairly potent cleaner wax so we wanted to see if we could maximize the cleaning ability of it.
    The brighter areas toward the nose of the car are after using White Wax, while the darker, duller areas are untouched.
  5. #35
    Jun 2013
    Beverst Bilzen Limburg Belgium
    22
    7
    While we're talking about White Wax, where does Black wax fit? I suppose about in between swirlX and M205 (I suppose ultimate pollish comes after M205 but only marginally)
    Or is it more aggressive than that?
  6. #36
    39
    19,107
    237
    Ult. Polish is milder than #205, and Black Wax should be milder than Ult. Polish.
  7. #37
    Jun 2010
    739
    19
    Wow, that's a dramatic difference!
    Looks like White Wax is going on the shopping list! Thanks for the info, Michael.
    Bill
  8. #38
    Sep 2005
    Sydney, Australia
    4,289
    64
    Thanks Michael.
  9. #39
    21,401
    1137
    Black Wax is quite a bit less aggressive than White Wax but it contains a lot more polishing oils, which darker colors really love. This graphic spells it out pretty well, comparing both Black and White Waxes to our original Cleaner Wax.
  10. #40
    Jun 2013
    22
    7
    Yeah, i already found that comparison chart on the website, but hoe does it scale to the other SMAT products?
    Maybe update the chart in the opening post by adding Light/Dark wax, and Ultimate pollish
    I know Dark wax is milder then Light wax, but now by what margin (compared to the other SMAT products)
    I mean, seeing that Light wax is appearantly more agressive than SwirlX, make's me wonder what Dark wax compare's to.
    Like if it could remove haze left behind by ultimate compound/M105
  1. How to properly use my product ?
    By stevIW in forum Detailing 101
    Last Post: May 17th, 2006, 04:59 AM
  2. NXT....uh
    By HammerDown in forum Consumer Line - Product Reviews
    Last Post: Sep 11th, 2005, 09:00 AM
  3. non clear coat finnish
    By starquality in forum Detailing 101
    Last Post: Jul 18th, 2005, 08:58 AM
  4. Replies: 5
    Last Post: Jul 15th, 2005, 11:12 AM
