The Aggressiveness Order of SMAT Products - This might surprise you! - Page 7
Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 78
Thread: The Aggressiveness Order of SMAT Products - This might surprise you!
  1. #61
    Feb 2015
    United States
    5
    6
    Re: The Aggressiveness Order of SMAT Products - This might surprise you!
    Your plan generally sounds good.
    I'm not familiar with the colors of GG pads, but I assume red is one of the softer ones for finishing / waxing? If so, then you're good to go!
    Just remember to do a test spot first to see if your process is giving you the results you're after, before repeating on the whole car. If UC is taking care of the major defects, then you shouldn't need to buy M205. Just follow up with your UP.
    VW's generally tend to have harder paint, but that's a generalisation. Every car is different - hence the importance of the test spot.
    Thanks. That helps. And was my plan, but good to be reminded so I don't just start right in on the hood before trying a test patch. And yes, that is right, the Griot's red is called the waxing pad. the black the finishing pad, and the orange the corrective pad.
  2. #62
    Aug 2010
    Fairmont, MN
    77
    1,443
    25
    Quote Originally Posted by fightnews View Post
    what about the mirror shine hi tech yellow wax? Is that made for a rotary as well?
    No problem...it's a wax. Hence application in independent on hand, or machine.
    Bill
  3. #63
    Registered Member billddrummer's Avatar
    Feb 2014
    Reno NV
    67
    207
    9
    Getting ready to work on the swirls on my Azera (weather finally cleared). UC with my 6" foam polishing pad (GG) and the HF D/A will most likely take care of the hood, trunk and roof. Was able to correct the door panels with the mirror glaze. And I will post some photos this time. Thanks guys (and gals)!!! Hyundai vehicles have hard paint. Which I found out when the paint laughed at my feeble first try. Live and learn.
  4. #64
    Mar 2016
    Las Vegas NV
    19
    5
    This has been a very informative thread.
    I come from a wood and metal working background. These industries use abrasives that are clearly defined as to their cut. It is very frustrating looking at car detailing abrasives and having no real idea as to what a product is capable of or how aggressive it is supposed to be. It's one of the main reasons I've yet to get into paint correction.
    Even knife sharpening stones are graded by grit. It must be in the overall industry's best interest not to standardize these things and rely on marketing to move their product.
  5. #65
    21,402
    1138
    Quote Originally Posted by Tempest View Post
    Part of the problem with trying to nail down a true measurement of cut with any liquid is that there are so many variables with regard to the use of said liquid.
    Just take M105 as an example: We have a cut scale on our Mirror Glaze Professional compounds and polishes, but that number is when the product is used as most generally intended. In the case of M105, that is in a body shop environment with a rotary polisher and a wool cutting pad. But what happens to the cut when you use it with a less aggressive tool, like a DA polisher? Is it a high torque DA like the MT300, or a weaker tool like an old school Porter Cable 7424? Or is it a tall stroke tool like a Rupes Bigfoot 21? Maybe a direct drive tool like the Flex 3401? And then how do you use that polisher? What speed setting? What amount of pressure? And what pad are you using it with? The variables are almost endless.
    When looking at wood working you obviously have different hardness of wood - pine versus oak versus mahagony - in different metals in metal working - aluminum, steel, stainless steel, copper, etc - but when working with paint the variables are, again, seemingly endless. Not only do factory paints display an enormous range of hardness, softness, touch sensitivity, etc but after market paints just expand that range. And with aftermarket paints, the painter can alter the characteristics of the paint depending on how he mixes it. Plus, paints can change as they age, just adding to the variables.
  6. #66
    Mar 2016
    Las Vegas NV
    19
    5
    A well written and argued post as usual, Michael.
    However, most of those variables exist in the other fields. The type and power of sander, as you say wood hardness, open coat vs. closed coat sandpaper...etc.
    Having a grit number gives a firm point of reference to the user as to how to proceed under the given conditions. Is 100 cutting too fast or coarse? Move to 120 or 150 etc.
    This cannot be easily done with paint correction products, especially across different brands or lines.
    Working time, ease of use, lack of dusting....these are much harder to define. But I don't think it unreasonable for the customer to know what level of material removal to expect from a product when they buy it.
    (Not trying to beat up on Meguiar's products. This seems to be pervasive across the industry.)
  7. #67
    Feb 2014
    Reno NV
    67
    207
    9
    Quote Originally Posted by billddrummer View Post
    Update: Didn't work on the finish last time I posted because the weather turned foul again.
    Will tackle it today with the HF D/A polisher (Chicago Electric brand, if anyone cares), GG foam polishing pad and UC.
    Thinking that I can go straight to UW after.
    Will figure out photos.
    2016 red Hyundai Azera, acquired with 21 miles. Drive 600+ miles/week. Commercial RE agent in CA focusing on properties in the Truckee/Lake Tahoe basin.
  8. #68
    Feb 2014
    Reno NV
    67
    207
    9
    UC got most of the swirl marks out with one application. Had to use the highest speed with the DA and heavy pressure, but it worked.
    after UW looks good.
    Will go with UC again the next time.
  9. #69
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,584
    65
    Glad you got most of it. The remaining defects could be RIDS
    I am going to recommend a test spot with the least aggressive polish and pad before you proceed next time. Compounds are more aggressive, meaning it is removing more paint that a polish.
  10. #70
    Feb 2014
    Reno NV
    67
    207
    9
    Great idea Guz, thanks!
    I reveal my ignorance--what is RIDS?
  1. How to properly use my product ?
    By stevIW in forum Detailing 101
    Last Post: May 17th, 2006, 04:59 AM
  2. NXT....uh
    By HammerDown in forum Consumer Line - Product Reviews
    Last Post: Sep 11th, 2005, 09:00 AM
  3. non clear coat finnish
    By starquality in forum Detailing 101
    Last Post: Jul 18th, 2005, 08:58 AM
  4. Replies: 5
    Last Post: Jul 15th, 2005, 11:12 AM
