Meguiar's Quik Tips Video Series - Consumer Headlight Restoration Kit.
After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
Cloudy, oxidized, and scratched headlights not only reduce your visibility, they also effect the appearance of your car. Replacing neglected headlights can be very expensive, but with our One-Step Headlight Restoration Kit, you can easily restore clarity to cloudy, oxidized, yellowed and even lightly scratched headlights using your own drill. We recommended use of a quality, corded drill rather than a cordless unit as these often lack the power and torque needed to remove many years of oxidation and scratches.
Begin by cleaning your headlights to remove any dust or grime, then simply attach the Meguiar's proprietary buffing pad and apply a nickel sized amount of Meguiar's PlastX polish onto either the pad or the headlight itself. Both the buffing pad and PlastX are included in the kit.
Place the pad flat against the headlight and turn on the drill. Use slow overlapping motions and keep the pad firmly against the headlight while buffing. Apply PlastX polish as needed and continue working until the headlight becomes clear.
For the final application, use the included microfiber towel to apply and remove PlastX polish by hand to reveal a like new headlight that’s brighter, safer and better looking.
