Should i wash them before use? Or should they be okay to use out of the package?
Just bought some wax applicator pads
Re: Just bought some wax applicator pads
Originally posted by Steveo47 View PostShould i was them before use? Or should they be okay to use out of the package?Ryan's Auto Detailing, S.A
Dominican Republic.
It's been couple months and I have been wondering the same things recently. I've gotten some answers and if you'd like more clarity, I'll share what I've heard:
First, like everyone says, always try the least aggressive method and move up from there.
Least to most aggressive materials: foam, microfiber, terry cotton.
For pure-polishing or noncleaner-waxing, you could get away with using any of the above; but, I would always stick with foam pads for applying because on these steps your are not doing any corrections so you just want to leave the smoothest/nicest finish + you'll probably waste less product because the foam doesn't aborb it as much.
For paint cleaning, on the other hand, there may be times you need to get more aggressive because your first method may not be doing the trick. Even so, I would still work with foam first and move up in aggressiveness from there.
You could even take half steps in aggressiveness. For example, when using a particular paint cleaner & applicator, applying more pressure or more speed will take it up another notch. Also, working a smaller area at a time could do more.
Also, from what I have read, another half step would be to go up a small step in product before going up a step in material. All things being equal, staying with a foam and moving up from say swirlX to scratchX may be less aggressive than going from foam to a mf or terry. Hope this helps and if somebody else feels I'm a little off let us know because I am in the same boat.2010 Subaru Forester 2.5x Prem - Obsidian Black
2006 Lexus is250 AWD - Tungsten Pearl
