Hi, I was reviewing the Meguiars training video How to Remove Paint Defects the other day, and at 12:09, when they were talking about Unigrit sanding paper, they said that the 2500 and 3000 grits were designed specifically for using on factory orange peel.
I know there are great cautions about trying to use wet sanding to remove factory orange peel in terns of taking off too much clear coat and affecting the UV protection. And I know you have to use a rotary to buff out the sanding marks. I have used 2000 grit on a test junk hood and had great results with it, at least cosmetically.
But I suspect the factory orange peel on my car will always bother me, so my question is just that if sticking to 2500 and 3000 grit wet sanding, is this relatively safe for factory orange peel? Is there data as to how many mil this process will take off of the clear coat?
