Originally posted by dave_st170
Thanks.
I finished with scratch X and apply a coat of NXT to the Focus and waited 1hr for it to dry (Car is in a warm garage)
Thanks.
The instructions state to apply a thin, even coat and allow it to dry to a haze. In most climates this wax will dry to a haze in 10 - 15 minutes, in colder, more humid climates maybe 5-10 more minutes, but it shouldn't take an hour to try to haze.
I buffed off with a MF Cloth and in some places i found smearing.
Only think i can think of is i did not get all the Scratch X off the panel.
Apply a second coat as I outlined above. Apply this second coat thoroughly, working the product into the finish and leaving a thin, uniform coating. Allow to dry for 10-15 minutes and then remove with soft, clean microfiber polishing cloths.
Now i have gone to a different panel and apply first DC2 and buffed off and now on the motor is NXT.
Will this stop it???
Thanks
Dave
Thanks
Dave
Washing
Before detailing your car, first do an extremely good job of washing it. Remove all the dirt from all the nooks and crannies. This prevents any small abrasive dirt particle from entering into the machine polishing process and potentially instilling a swirl. Get the Car Sparkling Clean to start with and everything will be downhill after that.
Claying
After that clay the car, at least the horizontal surfaces. Again, do a good job of claying to insure you remove all above surface contaminants. The level of gloss you can achieve from your car's finish is mostly determined by how smooth you can make your paint. Claying will make your car's finish as smooth as glass.
Cleaning
Cleaning is different than washing. Cleaning is removing both above surface defects like oxidation and below surface defects like swirls, scratches, etchings, and dirt that has embedded itself under the surface. Choose the appropriate paint cleaner for the condition of your car's finish and your application process. If you're unsure of which paint cleaner or cleaner/polish is right for your car, describe your car and if possible post a picture and we'll be glad to make some recommendations.
Polishing
Polishing after removing the defects is typically using a pure polish that is non-abrasive to restore brilliant high gloss and deep, dark reflections. This is an optional step and one best used on medium to dark colored car.
Protecting
This is where you apply your choice of wax or paint protectant. Adding a layer or two of wax creates a sacrificial-barrier on your car's paint to protect it and also add shine and gloss. Generally, two thin coats will insure even coverage with a uniform appearance.
Maintaining
Maintaining is the use of products like a quick detailer or a spray wax to maintain that "Just detailed look" in-between regular washings, and the regular application of a normal coat of wax.
Neither the paint cleaner, (ScratchX), or the polish, (Deep Crystal Polish), need to dry before removing. Basically, apply them, work them in and then remove them.
Then apply two thin coats of the NXT Tech Wax. Allow each coat to dry to a haze, this will take about 10-15 minutes in most climates. Then remove using clean, soft premium quality microfiber polishing cloths and a gentle touch.
Hope this helps...
Mike
