Re: Wet sanding, cutting and buffing using only a DA
I'm adding this post kind of for reference.
"PTG readings on the door averaged around 115 microns."
115 microns = 4.5 mil
"Total material removal was 8-10 microns"
8 microns = 0.31 mil
10 microns = 0.39 mil
(How do I know this? If you want to do a unit conversion like this, just type something like "8 microns in mil" in the Google search box).
So basically this process removed between 0.3 and 0.4 mil, which is inside the margin of safety that most auto makers allow for clear coat removal.
(The following are the maximum allowable clearcoat reductions the major USA car manufacturers will allow: Chrysler 0.5 mils; Ford 0.3 mils; GM 0.5 mils.)
