Help removing endurance tire gel
  • Help removing endurance tire gel
    I can't get all of the endurance tire gel off my tires. Its leaving them dull and greyish. I've tried the meguars wheel cleaner, dish soap and bleach white. None of them seem to get it all off. Any suggestions?
    07 Mazdaspeed3
    Re: Help removing endurance tire gel
    Spray Nine. Spray on let dwell for a few minutes and wash off. Should be good to go.
    Professional Automotive Reconditioning Services
    "You scuff it-I buff it!"
      Use some sort of degreaser like Meguiars Super Degreaser, let it sit for 15 -20 seconds, and agitate with a brush, then rinse. It may require a few application of degreaser and agitation depending on how heavy you put the Endurance on.
      Remove swirls my friends.
        Or a paint cleaner, metal polish as needed.
          But you mean the wheel or the rims?
          If itss the wheel then a few rounds of SD and APC would do it. Just put some passion on the brushing part
          Ryan's Auto Detailing, S.A
          Dominican Republic.
            If you are talking about the tire rubber, I would go with apc. It may take a couple of applications to completely remove.
              Sorry I guess I should have clarified. I'm talking about the tire. It doesn't get black anymore when I apply the gel.
              07 Mazdaspeed3
                In that case i have your solution .
                Heres what your gonna do:
                -Spray the tire with Super Degreaser 4:1
                -Scrub with a Brush.
                -Rinse the wheel.
                -Spray some APC 4:1
                -Repeat process of scrubbing and rinsing.
                -Buy some Endurance Low gloss tire gel.
                -Apply to all the wheels.
                -Get some NXT Insane Shine Tire Spray. And spray it to all the wheels.
                This process will really clean the wheels and the Endurance low gloss will restore the blackness of the wheel while the NXT will bring up the shine you want. Your wheels will never get brown or grayish. I use this process in my car and when i do a full detail my clients love it.
                Hope i helped you
                Ryan
                Dominican Republic.
                  Originally posted by the big buffer View Post
                  spray nine. Spray on let dwell for a few minutes and wash off. Should be good to go.
                  +1
                    Ive tried using a sponge and soap this didn't help me remove the endurance gel. I put it on every time I wash my car so maybe I do it too much.
                    i know this thread is old, but what's the best way to clean the whole tire, remove the gel, and re apply it?
                      ^^ This.
                        I use body solvent on most "gressy" tires and have never had a problem removing any dressing.
                        DetailingByM.com
