Thickness guage
  • Thickness guage
    Looking for something cheap to just mess around with. My truck has been repainted though so what's a good guage that will tell me how thick the clear is on top? I'm guessing this one won't work...
    Easy to Use with NO Damage to Paint Get the accurate thickness of the non-ferrous coating on steel with the ProGauge II Magnetic Paint Thickness Gauge. This state of the art equipment is easy to use and gives you an accurate reading of non-ferrous coating on steel with a range of 1 to 15 mils. Most of the magnetic gauges available today do not compensate for the gravity effect. As a result, the readings for similar paint thickness may vary up to 40% when measured on top and side panels. With our ProGauge II Magnetic Paint Thickness Gauge, you get an accuracy of more than .001 of an inch. The manufacturers of the Paint Thickness Gauge are the leading developers of PB and E equipment. They develop premium quality items like paint inspection tools, electronic thickness gauges and many more. The ProGauge II Magnetic Paint Thickness Gauge is a user-friendly device and gives accurate measurements. Armed with this tool, you can now accurately know when the panels are repainted and also when the paint is too thick or too thin. If the paint is too thick on the surface, problems such as cracking and other paint failures may occur. With this hassle-free tool, you can understand the thickness of the paint easily to make a better decision. This tool is so user-friendly that all you have to do is just place it on the paint and read the scale while pulling the gauge. It has a large indicator and clearly marked scales for ease of use. The magnetic power on the ProGauge II Magnetic Paint Thickness Gauge gives longer holding power, and this tool is very popular among car collectors and insurance adjusters. It comes in a heavy duty case for easy storage. You can carry it anywhere as it fits into your shirt pocket. This thickness gauge instrument includes a complete instruction booklet with information on automotive paint thickness and factory specifications. This product is made in the USA. Key Features of the ProGauge II Magnetic Paint Thickness Gauge: Measures the thickness of non-ferrous coatings on steel with a range of 1 to 15 mils Easy to use by just placing on paint and reading the scale as gauge is pulled off the paint Fits in your shirt pocket Used by car collectors and insurance adjusters Causes no damage to the paint
    Re: Thickness guage
    The gauges that measure only "top coat" are very very very expensive.
    The gauges that we recommend for paint correction are the digital ones since you need to be very very accurate. We're talking tenths of a mil.
    Gauges like that are used to determine out much total material is being removed...
    Before Repair = X
    After Repair = X
    _______________
    Diff = total "top coat" removed...
    That said, the above gauge would not be a good choice for determining top coat film build or paint correction measurments...
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
      Re: Thickness guage
      Dang I was hoping to get by cheap lol Probably start investing in one.
        Re: Thickness guage
        Before Repair = X
        After Repair = X
        _______________
        The only one I am aware of that can measure the various layers is the Delfesko Positector 200 which is for measuring layers on non-metal surfaces. Even so, it is extremely expensive!
        Tim
        Tim Lingor's Product Reviews
          Re: Thickness guage
          http://www.autobodytoolmart.com/prog...e-p-10805.aspx
          Same one for less. If all you need to do is find out (on a rough scale) if a part has been repainted, or if there has been body work, this would probably be accurate enough.
          As has been pointed out, for the purpose of measuring how much clear coat a process is removing from factory clear coat, it wouldn't be accurate enough.
          But the good news is, you say your car has been repainted. This means, as I understand, that your car should have enough clear coat for you to do whatever you need to do, remove orange peel or defects or whatever. It is only the factory clear coats where you need to be careful trying to wet sand to remove orange peel because these clear coats are very thin. As I understand, and someone correct me if I am wrong, a repainted car you can pretty much do whatever buffing or wet sanding you need to do.
            Re: Thickness guage
            Hey Mary,
            Not exactly. Generally you need to tell the painter that you are planning to wet sand and buff the paint. They way, he/she will lay enough clear so that it can be rubbed out perfectly flat. Many body shops use the bare minimum of clear in order to keep costs down. Moreover, depending on that person's skill along with the contour of the vehicle, some areas may have more or far less film build. Hence, multiple readings must be taken all over the vehicle. Then a test spot must be done and measured with before and after measurements. Some paints are very hard and can take considerable buffing while others can be incredibly soft and a simple buffing can remove large amounts of clear.
            Delfesko makes a smaller PTG that works very well and is very accurate. But as mentioned, in this case you do have to spend in the $500-700 range for a decent gauge.
            Tim
              Re: Thickness guage
              Thanks, Tim.
              What do you think of this one? It measures to within 0.1 mil, which I think is as good as you can find.
                Re: Thickness guage
                This link has the comparison chart of Highline Meter with other meters
                  Re: Thickness guage
                  Sorry for my 3 posts in a row.
                  I was just googling on what people had written about the Highline and found this interesting quote:
                  "The highline meters are very accurate and are a budget paint thickness gauge that gets the job done on all metals (without calibration every time you switch). If you want to see how thick the clear coat is then just check under the hood where there isn't any clear coat. then check a surface with clear coat, and then the difference is roughly the thickness of clear coat only."
                  So of course I ran out to my car and looked under my hood. The paint does look a lot more dull there. I guess you would have to test it in several places to see if this really gives an accurate reading of what your non-clear paint layer is, but it is an interesting theory anyway.
                    Re: Thickness guage
                    Thanks, Tim.
                    http://www.highlinemeter.com/
                    Hi Mary,
                    I have seen that meter (or a clone of it) before, but have no experience with it and as such can not say if it is any good or not. One of the problems with cheaper meters is their lack of consistency. When it comes to measuring paint, having a consistent meter is extremely important. With the meter you sourced, like I said, I have no idea if it is any good or not. I would search the detailing sites and ask people that actually have and use one for their assessment of it. Any comparison charts etc I always take with a grain of salt. Generally, this is one of those times that you usually get what you pay for....
                    As for measuring the paint under the hood, again, I am not sure if that would be an accurate way to go or not. It depends whether or not a full primer and base coat was used on the underside and whether or not all manufacturers use the same painting procedures. That is what makes wet sanding so tricky as one can still have all of the measurements and still because of discrepancies, sand through to the base coat. One must be very careful as a mistake can be very expensive...
                    Cheers!
                    Tim
                      Re: Thickness guage
                      Thanks, Tim!
                      Personally, I'd be a happy camper if they would rent those gadgets at the local rental centers.
                        Re: Thickness guage
                        Thanks, Tim!
                        You are very welcome!
                        You know, with the availablility of electronic devices in today's digital era, you would think they should be able to produce a good PTG at a good price. Heck we have iTouch players that do every thing but make toast!
                        Tim
