How to remove bugs from windscreen without damage
Results 1 to 10 of 17
Thread: How to remove bugs from windscreen without damage
    Registered Member Bill Davidson's Avatar
    Apr 2010
    Edmonton, Alberta, Canada
    1,166
    25
    I'm looking for suggestions on methods to clean bugs off of a windscreen while doing minimum or no damage. Nothing worse than a scratched/hazy windscreen on a pretty cruiser.
    Let's categorize this:
    1-Fresh
    2-Baked
    I have a few thoughts of my own but I'd like to here yours first.
    Registered Member Fly Bye's Avatar
    Nov 2009
    Nor Cal
    55
    731
    19
    Re: How to remove bugs from windscreen without damage
    Quote Originally Posted by Bandit Bill View Post
    1-Fresh
    I use a micro fiber with instant detailer. The mf should pretty damp. The wetter, the better. I get it as wet as possible without liquid running down. If you're to the point of liquid running down, may as well just use soap & water and get the whole bike wet.
    2-Baked
    You could soak a mf with soap/instant detailer, and lay it out on the plastic so that the debris being removed is soaking. Soaking is key to loosening dryed/baked on bugs, which prevents having to scrub the plastic windscreen.
    I sometimes just hose down the whole bike if it's really dirty. If you gently wipe the windscreen down with a heavily saturated sponge, (soap & water/instant detailer) whatever solution you use will prolly run/drip down, meaning you will be cleaning more than just the windscreen. then hit it again after 4-5 minutes, the hardened debris should have loosened, thus letting you easily remove it.
    Jan 2009
    New Lenox, Illinois
    10,362
    302
    Soap and water and a bug sponge:
    I used PlastX on this Victory motorcycle
    Nov 2009
    Nor Cal
    55
    731
    19
    If the windshield is not that bad, you could use a saturated mf with the solution of your choice, and just use a second mf to stop the drip from dripping on other parts of your bike.
    Apr 2010
    1,166
    25
    Thanks for the suggestions.
    Tuck, isn't PlastX being a cleaner and a polish a bit too much for day to day use?
    A friend of mind just got a windscreen installed on her Harley ($800 installed) and I don't want her to scratch it up washing her bike. I like Fly Bye recommendations of a (5 minute soak) with a microfiber. Just because this thing is brand spanking new.
    With that additional information, would you still recommend day to day cleaning with PlastX?
    For Baked: I was thinking more along the lines of M17 Clear Plastic Cleaner. Perhaps letting a wet towel (water) sit on it for a few minutes, followed up with M17 on a microfiber.
    For Fresh: probably a spray with the hose, followed up by M17 on a microfiber.
    What do you think?
    Jan 2009
    New Lenox, Illinois
    10,362
    302
    What do you think?
    No, just use the PlastX a couple of time a year and maintain it with M18 Clear Plastic Detailer.
    I did not mean to use the PlastX often or from day to day use.
    Nov 2009
    Nor Cal
    55
    731
    19
    For Baked: Perhaps letting a wet towel (water) sit on it for a few minutes, followed up with M17 on a microfiber.
    What do you think?
    Before you use the M17, make sure you have all the debris off of the windscreen. M17 is more for removing fine scratches, thus is not something I would use everyday. Were talking about removing bugs off of a plastic windscreen from daily rides.
    As far as fresh bugs, I would not spray the windscreen with a hose unless I was planning on cleaning other parts of the motorcycle, as a hose will surely get other parts of the motorcycle wet. I probably wouldn't use a hose unless I was indeed going to wash/clean the whole motorcycle, or the windscreen was really, really bad.
    I have never had a problem with cleaning/removing bugs on my R1. If there are a lot of dried bugs on the windscreen, I may gently go over it with a saturated mf. If the bugs are really adhered to the windscreen, I may just saturate a mf with a type of liqud, and just lay it on the windscreen for 4-5 minutes, and then gently wipe away the bugs. If they don't all come off at this time, they will definately, easily come off with a second gentle wipe with a clean, saturated mf.
    Feb 2009
    Powell, Tennessee
    33
    3,543
    133
    Autogeek just came out with a kit for bug removal: http://www.autogeek.net/diamondite-bug-eraser-kit.html. The Waterless Bug Remover and the Surface Protectant are both on BOGO right now if you want to buy them separately (not in the kit). Just an FYI.
    Jan 2009
    New Lenox, Illinois
    10,362
    302
    Quote Originally Posted by CieraSL View Post
    The kit seems a little too pricey just to remove some bugs, lol.
    Although the surface protectant does look interesting, might get better results just by applying some wax or sealant or spraying Body Solvent on the front of the car before a road trip.
    Apr 2010
    1,166
    25
    Stupid me I was thinking cleaner as in (non abrasive like soap).
    Dumb mistake.
    Thanks for the tips.
  1. Using the G-100 to remove swirls, scratches and etchings...
    By Mike Phillips in forum Machines - The Dual Action Polisher
    Last Post: Oct 19th, 2009, 02:56 PM
  2. Bugs, Bugs, BUGS, and MORE BUGS!!!!!
    By Tillmanator in forum Hot Topics & Frequently Asked Questions
    Last Post: Oct 27th, 2008, 02:41 PM
  3. Hard Water Spots on my 2005 Chevy Truck
    By Nevada in forum Detailing 101
    Last Post: Dec 22nd, 2006, 02:39 PM
  4. why won't this work?
    By fordraceing_man in forum Detailing 101
    Last Post: Sep 27th, 2006, 09:14 PM
  5. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
