Meguiar's Quik Tips Video Series - Removing Swirls
Results 1 to 10 of 18
Thread: Meguiar's Quik Tips Video Series - Removing Swirls
    21,401
    1137
    NOTE: Since this video was produced we have added Ultimate Polish to our lineup. Everything you see in this video and the rest of the post can be done with Ultimate Polish, too, using the same techniques. Keep in mind, however, that Ultimate Polish is a very light duty cleaner/polish and is most commonly used following an application of Ultimate Compound. Used in this was, Ultimate Polish will enhance the gloss of any finish, but used on it's own it can remove very light swirls from your paint finish.
    After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video.
    Regardless of whether or not you’re a car guy, swirl marks are a problem for everyone. Lets face it, there’s nothing attractive about a car with swirls. They can be isolated or widespread and removing them is crucial to getting your car looking it's absolute best.
    To remove swirls Meguiar's developed Ultimate Compound and SwirlX swirl remover - both are quick yet safe solutions for use by hand, orbital buffer, or even our G110v2 Dual Action Polisher.
    Begin by washing and drying your car thoroughly and, if needed, clay your car using our Smooth Surface Clay Kit.
    If you are working by hand, apply either Ultimate Compound or SwirlX swirl remover with a foam applicator and work one section at a time with overlapping strokes.
    There is no need to let either of these products dry; simply wipe them off using our Supreme Shine Microfiber Towel, turning to a clean section for your final wipe.
    If you are using our Dual Action Polisher we recommend using our yellow W8207 Soft Buff 2.0 Foam Polishing Pad. Simply attach the foam polishing pad and set the speed to approximately 4.5 - 5. Apply Ultimate Compound or SwirlX directly to the pad and place the pad flat on the paint.
    Turn the machine on and begin buffing with moderate pressure in an overlapping pattern while keeping the pad flat against the paint at all times. Work a small section at a time, applying additional SwirlX as needed until all swirls have been removed.
    Remove the product residue using our Supreme Shine Microfiber Towel.
    There you have it, a swirl free finish ready for your favorite Meguiar's polish or wax. (We've only corrected the bottom half of the panel in the image below in order to show a distinct before/after difference)
    Registered Member macmaster's Avatar
    Jan 2011
    CA
    47
    9
    Re: Meguiar's Quik Tips Video Series - Removing Swirls
    I don't understand, is that last picture polished or not? It looks like it has a lot of swirls to me...
    21,401
    1137
    It's a half and half; typically we tape off a portion of the panel and polish out one section, then we remove the tape so you can dramatically see the before and after side by side. Look at the panel in the picture - yes, the upper half is horribly swirled but the lower half is swirl free after going through the buffing process.
    Jan 2011
    CA
    47
    9
    Thanks for the explanation. Makes so much sense now. Looks great too!!!
    Aug 2010
    Fairmont, MN
    76
    1,415
    23
    Funny how we get use to looking at something one way only. I was thinking the same thing till I realized the tape line was horizontal v vertical.
    Was that a viewer test Mike? LOL
    Bill
    Apr 2011
    new york
    9
    heidy
    Jan 2012
    Atlanta, Ga
    23
    8
    I'm having trouble removing swirl marks with my DA using M205 with the yellow polishing pad. instead of removing them it seems like it puts them in. I've tried to follow up with mirror glaze swirl remover but I cant get them to disapear.
    21,401
    1137
    Quote Originally Posted by DavidReyJr. View Post
    What kind of car are you working on, how bad are the swirls?
    M205 is generally a very light duty final finishing polish, so even with a polishing pad instead of a finishing pad it might not be aggressive to accomplish the task. The hardness of the paint and the level of swirls will play a large role here as well. But there's no way in the world that M205 or a polishing pad (assuming it's clean, of course) will put new swirls into the paint. Any chance you can get us a picture or two of what you're seeing?
    Jan 2012
    Atlanta, Ga
    23
    8
    I'm working on my 07 Jag, The pads that I'm using came strait out of the bag. maybe if I use the finishing pad with the same polish I might get better results.
    21,401
    1137
    If you're using a polishing pad with M205 and that's not removing your existing swirls, then moving to a finishing pad isn't going to help. You'd just be getting less aggressive when it sounds like you need to get more aggressive. We would suggest using Ultimate Compound on the polishing pad at speed 5 and with moderate pressure to remove the swirls, then optionally using M205 on the finishing pad at a slower speed and less pressure to further refine the finish prior to waxing. We say "optionally" because you may not need a step between Ultimate Compound and wax, or you may want to shoot for a higher level of gloss.
  1. Replies: 14
    Last Post: Feb 5th, 2013, 04:18 PM
  2. #21 by hand ?
    By hardisk88 in forum Detailing 101
    Last Post: May 17th, 2006, 09:23 AM
  3. Meguiars Detail Center - What to do?
    By herb in forum Detailing 101
    Last Post: Jun 9th, 2005, 07:31 PM
