Car Shampoo as clay lube
Results 1 to 10 of 10
Thread: Car Shampoo as clay lube
    EPHIOS EPHIOS's Avatar
    Jul 2008
    Las Vegas, Nevada
    800
    20
    Ok, I know there have been many threads like this. However, I been reading a lot of thread from other forums, and they are using GC Shampoo as a clay lube. Can GC Shampoo really be used as a subtitute for Last Touch or Final Inspection? Also, I heard that car wash shampoo will quickly breakdown the clay bar compare to quick detailers. Is this true? Guys, what do you say?
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    61
    Re: Car Shampoo as clay lube
    I read it somewhere else in this forum, but the shampoo will break up or dissolve the clay. Car shampoos are more commonly used as a wetsanding or damp sanding lubricant.
    Registered Member SVT Lightning's Avatar
    Jan 2005
    929
    25
    I have used GC as a clay lube and it works great. But it does cause the clay to break down faster.
    Black......the ONLY color!
    Jan 2009
    New Lenox, Illinois
    10,362
    301
    Theres a chance you could marr the paint up.
    Theres a thread on here somewhere where GC was used as a clay lube and there was a lot of marring when the car was in full sun.
    Its cheaper to use LT at 1:1.
    Sep 2005
    14,251
    537
    Your clay will break up sooner. I would stick with the Last touch, or qd for the lube.
    Registered Member FRS's Avatar
    May 2010
    Sydney, Australia
    620
    17
    Quote Originally Posted by EPHIOS View Post
    Why would you use shampoo in the first place as Quick Detail-er is cheap and safe.
    Feb 2010
    Suffern, NY
    28
    2,841
    54
    LT at 1:1 is very cost-effective. 2 gallons for $20, $10 a gallon. Opposed to $5 for 32 oz Quick Detailer which makes $20 per gallon of clay lube.
    Dec 2007
    79
    What clay are you using? If it's megs than better use QD or LT. I've used it with soap once and it dissolve the clay rather quickly, so big No No! 3M Clay would work fine with their soap, but i wouldn't recommend it as the soap residue could get messy and you need to hose it down to remove remaining soap.
    Registered Member Fly Bye's Avatar
    Nov 2009
    Nor Cal
    54
    731
    18
    I use nothing but car wash shampoo as a clay lube. Never had an issue, never had clay degrade. Marring could be caused by a medium/aggressive clay no matter what lube is used.
    Jul 2008
    Las Vegas, Nevada
    800
    20
    I am using Mother's clay bar. I am asking this question because I have a lot of DC Car Wash and GC Shampoo on my cabinet. Just a bit curious. I do have two gallons of LT.
  1. How to mix your car wash solution
    Last Post: Oct 2nd, 2017, 01:26 PM
  2. Assessing Paint Thicknesses - Getting The Most Out Of A Single Layer PTG
    By Kickin Griffin in forum Machines - The Rotary Polisher
    Last Post: Jun 12th, 2009, 07:13 PM
  3. My Meguiar's Detail Clinic Article was Printed!
    By tekygeek in forum Detailing 101
    Last Post: Nov 28th, 2005, 09:32 PM
  4. Meguiars Detail Center - What to do?
    By herb in forum Detailing 101
    Last Post: Jun 9th, 2005, 07:31 PM
