G110V2 Pad not spinning
  • #16
    Re: G110V2 Pad not spinning
    Originally posted by SFC View Post
    Maybe I should have elaborated on my case specifically.
    My machine worked fine for about 6-8 months. I would in no way call it junk. It is a really good machine and I really enjoy using it. I know that the machine isn't a defective machine because it did work properly at one point. I also know that it isn't due to my technique because, again, it did work for me at one point.
    Now the pad will spin, but I have to actually lift the machine a bit. If I try to polish with just the weight of the machine then the pad will stop spinning and it then just vibrates. This happens on completely flat surfaces, so there is a problem. If anyone has any suggestions on what I should do to try and fix it, I would greatly appreciate it.
    thanks!
    If something has changed with the behavior of the tool then there is something amiss with the tool. Please contact Customer Care at 800.347.5700 to see about a replacement. And please accept our apologies for any inconvenience associated with this.
    • #17
      Well I switched the brushes out and it seemed to be running a lot stronger. I will take it in with me tomorrow and put it on some paint to know for certain.
      Pretty sure that was your problem. Please let us know your results
      • #18
        Hmmm, OP is in the town over - Makes me want to go over to see if it really is just a bad machine. I would assume something already posted in this thread is the sole reason of the pad "not spinning" though.
        • #19
          Roadtrip
          • #20
            I am glad to report that swapping the brushes has fixed the problem. I guess I didn't realize how much I had actually used the machine; easily a couple hundred hours over the course of 6-8 months.
            Big thanks to everyone for the responses and especially Flash Gordon for the fix!
            • #21
              Your very welcome. Glad I could be of assistance to you
              Now if I could just solve this other fellas problem
              • #22
                Cut the cord off where they crimped it and resplice it. I had the same exact problems
