Meguiar's New 3 Inch Professional Headlight & Spot Repair Kit
Look what Max dropped off in the Show Car Garage Studio for us to test out...
Meguiars Professional Headlight & Spot Repair Kit
After opening the box you'll find a soft case that hold everything inside with extra pockets on the outside for other tools or accessories...
Here I've spread everything out to show the complete selection of products found in the kit...
There are two backing plates with 4 different adapters which enables you to attach the backing plate to just about every known thread size used for small air tools.
The kit comes with 2 Chicago Pneumatic Air Tools, one is a Mini Dual Action Sander and the other is a Mini Rotary Polisher and both are clearly marked on the outside housing.
The Mini Dual Action Sander
After determining the correct adapter for sander you rotate the black hub until you see a hole align with the cutout on the exterior casing.
The kit comes with a wrench and a dowel type rod with a handle.
Place the steel shaft of the dowel through the cutout to pin the rotating assembly against the housing, this will enable you to attach the backing plate and tighten the backing plate to the rotating assembly.
Now you're ready to attach the foam interface pad...
The Meguiar's 3 inch Spot Repair Kit uses hook and loop style interface, so align the loop side of the interface pad, (the side with the "M" on it), and attach to the hook side of the face of the backing plate and do your best to align so it's centered or true.
Next select the grade of Unigrit Disc you want to use and align it to the interface and press on firmly.
Here's the sander with interface and Unigrit sanding disc attached...
You're ready to go to work...
Kit includes:
1 Pneumatic Mini DA Sander
1 Pneumatic Mini Rotary Polisher
50 S3320 Unigrit 320 Grit Sanding Discs
50 S3500 Unigrit 500 Grit Sanding Discs
50 S3800 Unigrit 800 Grit Sanding Discs
15 S3F1000 Unigrit 1000 Grit Finishing Discs
25 S31500 Unigrit 1500 Grit Sanding Discs
15 S3F3000 Unigrit 3000 Grit Finishing Discs
1 S3FIS Unigrit Foam Interface
2 W4003 3” “Easy Buff” Knitted Wool Pads
2 W7204 4” Soft Buff Foam Cutting Pads
2 W8204 4” Soft Buff Foam Polishing Pads
2 W9204 4’ Soft Buff Foam Finishing Pads
2 S3BP 3” Professional Backing Pads and Adaptor Kits
1 S3HP 3” Professional Hand Pad - 1 ea
1 W63 3” Professional Rotary Backing Plate
1 T18MM Professional Masking Tape .75in
1 8 oz. Meguiars 105 Ultra-Cut Compound
1 8 oz. Meguiars 205 Ultra Finishing Polish
1 Meguiar’s Black Canvas Bag
1 Professional Headlight and Spot Repair Chart
This is a very complete kit with everything you need to refinish headlights that have deteriorated to the point where only sanding can save them and/or for doing spot sanding or spot damp-sanding to remove isolated defects out of fresh paint or factory paint.1 Pneumatic Mini DA Sander
