Bissel Little Green Machine Pro Heat questions?
  • Bissel Little Green Machine Pro Heat questions?
    hey guys, i just bought one tonight, and im wondering how to go about adding the APC+ to it for a correct ratio of APC+ to water. Do i add APC+ concentrate or a pre diluted mix or what. im confused on this and need to know so i can use it tomorrow
    Zach Hall
    Re: Bissel Little Green Machine Pro Heat questions?
    anyone????? i need to use this today and i want to know how to properly mix the APC+ with the water, do i use APC concentrate to the machiones line, or do i use pre diluted APC or what?!?!?!?!?!?!
    Zach Hall
      Hi Zach, here is what my bottle of APC+ says on it: General cleaning (cold water extractors) 20:1, (hot water extractors) 64:1.
      So I think you could probably start with something in between, like 40:1 or since it uses hot water but isn't a true hot water extractor. Then make adjustments from there.
        When I had the LGM what I did was just have APC in my sprayer diluted as always (10:1 or 4:1) and I just put on the LGM water without any solution. Spray APC and use heated water and clean away
          I use warm water with some APC from the dilluted bottle. Also for heavy stains I just spray some APC, use a brush and work it in and finally use the LGM on it.
            If you look at the back side of the tank, you should see 2 fill lines- one for detergent- your APC+, and one for the full mark. I just fill with APC+ to the first line and add (hot) water to the full line.
              BLGM was a waste for me .... Clogged, after the second time and the sprayer stopped working. Returned it back to WallyMart and bought a Mytee Lite II.
              Heats the water to 200 degrees in two minutes and the vac has good ****.
              regardless you still need to apply APC directly to pretreat your stains, agitate with a brush then extract
                The LGM for me has been wonderful, its extracted 90% of the water and has worked well on the van im doing. Also, i dont have 800 dollars, nor do i need an 800 dollar extractor.
                Zach Hall
