Hey guys, so ive been using APC+ mixed @ 4:1 for pre treating the carpet, then agitating, using LGM to spray hot solution, re agitating and extracting. Is it ok to use the same process on cloth dodge caravan seats? Is it a bad thing if they end up getting to wet?
Bissel LGM on cloth seats?
Re: Bissel LGM on cloth seats?
I use pretty much the same process on carpets, however, I always follow up with my wet/dry vac to make sure I get out as much water as possible. Now regarding the seats I dont see much trouble as long as you are making sure not to saturate the seat its okay to make several passes.
Personally I like to do cloth seats by hand, I believe Nappers has a post up where he did a neon by hand and thats the process I go by. This allows me to be safe and not use to much water. Though this takes much longer. Thankfully I dont have to do many cloth seats
Edit: I normally tell the people to crack their windows at night incase the floors or seats are still a bit damp so they have ventillation to dry overnight.
