what is the best order to apply
Results 1 to 10 of 19
Thread: what is the best order to apply
    Registered Member quikz28's Avatar
    Jun 2010
    Rhode Island
    59
    9
    im mainly looking to get rid of some light swirls. i have scratch x2.0 , megs paint cleaner, megs polish, as well as meg cleaner wax, gold wax, and to finish it off nxt 2.0
    i was wondering what is the best order that i should apply everything in.
    i was thinking apply in this order
    scratch x
    megs paint cleaner
    megs paint polish
    cleaner wax
    gold class wax
    nxt 2.0
    let me know what u think
    thanks
    Jun 2010
    Rhode Island
    59
    9
    Re: what is the best order to apply
    just to correct, i have swirlx if it makes a difference
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    I would do this:
    Scratchx 2.0 (it is the 2.0 I hope)
    Megs paint polish (Deep Crystal Polish?)
    NXT 2.0
    Gold Class Wax
    The Deep Crystal Paint Cleaner is not really needed after Scratchx 2.0 unless there was some hazing after Scratchx 2.0. In usual circumstances, there should not be any hazing so DC1 (Deep Crystal Paint Cleaner) would not be needed.
    Cleaner Wax cleans, polishes and protects. If you apply it after the polish then the layer of polish you just layed down will be nullified beause the cleaner wax just removed it.
    The NXT 2.0 topped with Gold Class is a great combo. Since NXT 2.0 is a paint sealant, you should apply it as the base and then Gold Class as the top coat as it is the carnauba blend.
    You could also try using Swirlx before Scratchx2.0 as it is the less aggressive of the two.
    Jun 2010
    Rhode Island
    59
    9
    sorry to be kinda vague,
    yes the paint cleaner and polish are deep crystal system
    do i apply very little swirlx, very lightly and take it off wet or do i apply some pressure to it?
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    Apply some pressure to it. You need to work the product against the finish. Use a Hi-Tech Foam Applicator pad and work the prodcut with some passion. Remember to use the base fo the fingers as pressure, not the tips of the fingers. Wipe it off when the product is translucent and/or when you feel the product not working as well (you will need to use it on order to know exactly). Do not let it dry.
    You may want to pick up some Ultimate Compound also. It is significantly more aggressive than Swirlx and that may be necessary in order to achieve the results you desire.
    Working by hand can be a daunting task. Patience is the key. It may take several applications of product before seeing the results you want.
    For reference, what color are you working on?
    Jun 2010
    Rhode Island
    59
    9
    victory red, im not to worried about doing it by hand, just making sure that i am using it properly to try to get the best results. the swirls are not that bad
    after your last post i realized that im making a couple mistakes in my order. i have never used swirl x before
    my order before was mainly
    megs dc paint cleaner
    megs dc paint polish
    cleaner wax
    gold class
    then nxt as a final wax
    the combo of the paint cleaner and polish did a decent job of removing some of the swirls but im looking to get as much as i can out
    i beileve i saw your post of when u used swirlx on your mini and i was very impressed, im hoping to have mine come out like that
    Feb 2010
    Suffern, NY
    27
    2,841
    53
    If you put the time into it, the results will be very good as you saw. I recieved a G110V2 as a gift about a month ago and I have used on several cars including my own: http://meguiarsonline.com/forums/showthread.php?t=43479. It really makes the job easier and gives superior results than hand application. However, that is not to say that with time, amazing results can be ahd by hand also.
    Swirlx is more abrasive than DC1 and will remove more imperfections. It is a cleaner/polish and also has some polishing oils that will really bring the paint up to a high gloss, especially on the dark reds, blacks, blues, and greens.
    I am sure you will do fine. Remember to read through how to maintain the vehicle so that it remains in top shape for as long as possible.
    Oct 2009
    In the office
    697
    16
    Quote Originally Posted by coopers23 View Post
    Agreed on both accounts.
    I have been Championing #7 Show Car Glaze as a base, then NXT 2.0 and then Hi-tech yellow for the top layer as it is a carnuba. CHeck the Show case results section on my recent details.
    Swirlx get a lot out. IF its bad such like oxidation, I go right to Ultimate Compound. Here is a recent Trans Am I did.
    Jun 2010
    Rhode Island
    59
    9
    ?what does work against the paint mean, rubbing in a certian direction? or just rubbing it it
    38
    19,070
    235
    How to correctly apply ScratchX to remove swirls and scratches
    You can probably look on Youtube for more.
    Just be careful to use your palm/across your fingers, dont use your finger tips.
  1. Old article from 1994
    By alkemyst in forum The Break Room
    Last Post: Mar 18th, 2008, 03:01 PM
  2. back order items
    By bentrue in forum Customer Service Hotline
    Last Post: Mar 7th, 2008, 11:42 PM
  3. What else should I order?
    By mis3 in forum Machines - The Dual Action Polisher
    Last Post: Mar 10th, 2007, 09:19 AM
  4. I need help
    By blackXterra in forum Detailing 101
    Last Post: Jan 29th, 2006, 03:50 AM
  5. New here, have a question
    By ninous26 in forum Detailing 101
    Last Post: Dec 30th, 2005, 01:44 PM
