Hi,
I'm the proud owner of a 1995 Toyota MR2 Mk2 Rev3 which I recently bought in the UK and brought back to France.
Being a red model, it has suffered from the sun and weather over it's 15 years and has lost it's original bright shiny red appearance.
In areas it is quite heavily oxodized - dull white / pink finish; in others it has suffered from previous polishing - general swirling and mat areas having lost their gloss.
For starters I spoke to one of your guys at this year's Le Mans 24 races in France who demonstrated the use of Ultimate Compound on an area of a red Corvette which had similar issues to mine. I was impressed!
I intend, after using Meguiars Quick Clay, to apply the Ultimate compound by hand using Meguiars foam applicators then finish by a couple of coats of Tech Wax 2.0 and a coating of Ultimate Quick Detailer.
Sounds simple, right?
My first question is for the Compound - how much should I put on the applicator for each section and how much pressure should I apply?
Should the paintwork look quite shiny after this process?
I'll be using an electric polishing tool with lambs wool cover to apply the wax, does this sound like a good idea?
What kind of issues / errors can I expect.
I'll be starting with a test on half the engine cover (which I will be replacing anyway) : Should I test all processes before continuing with the rest of the car?
I've never done this before so am a little worried about getting it wrong - it all looks so easy in your demo videos
Thanks in advance
Best regards
Clive
Thanks in advance
Best regards
Clive
